Question about Maytag MDE2400AYW Neptune Electric Dryer
Neptune dryer I have an early model, first or second year they were sold. It appears that the back is one piece with the sides. How do I access the interior to replace the drive belt and refix one of the "paddles" inside the tumbler ?
You have to tear the whole thing apart. when the last screw comes out make sure you have some extra hands to help.
Posted on Nov 08, 2007
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
When the dryer is run on high it shuts off early and a PF is displayed on the panel.
Could be your circuit breaker is bad, I had this problem awhile back. Or the thermistor could be bad. Easy enough to order parts and replace yourself to save money. Just google it for your type and model of dryer to get parts.
Sep 14, 2013 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
How do I access dryer drum for neptune dryer
take the door screws off and take the opposite side screws off lift out the door, grab the vertical pieces of the front panel and twist them away from the opening while you pull out, then lean the panel forward about 2 feet and lift the panel up and out, this gives you access to the lint screen housing and the blower wheel and housing and eventually the entire heating element and belt, drum, motor etc. unplug this thing before you work on it !!! it will zap you !!
Sep 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
A piece of the steel srum tore out during drying
If you can find a friend who is also an amateur welder or a professional,,you can have that piece welding back in for cheap,,,P.S. you will have to repaint the inside of your drum though afterwards
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag electric dryer INTERIOR ehaust vents have come apart and are obviously not exhausting hor air through the side opening.
take of screws holding door on, and screws opposite door hinges. the front will know be able to take off. just unplug first.
Oct 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
8.8. on Display
Mine had a fried control board. $150.00 for the part, did the work myself. Will not be putting any more money into these Matag Neptune pieces of junk after this. Will buy another brand of washer and dryer.
Feb 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to access rear of dryer
Need to know brand and model number.
Nov 19, 2007 | Dryers
Maytag MDE2400AYW Neptune Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
