Question about Zanussi Ovens
Fan not spinning and screeching noise zannusi cooker
2 Suggested Answers
  • 93 Answers
SOURCE: fan screeching on my gas oven, if it packs in can
You cannot use the oven on fan forced- buy a new fan motor
Posted on Aug 29, 2009
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Fan screeching on my gas oven, if it packs in can i still use the cooker ?
Aug 28, 2009 | Ovens
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
Ovens Logo
15 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
