Question about Motorsports
Where is the air conditioner blower on BMW 325ci
    Sergeant:
    Champion:
  • 253 Answers
Pretty sure there is only one blower motor for both the heater and a/c.. does the blower work when it's on heat..if it doesn't then try to find the fuse to see if it's blown otherwise you need a new blower motor
Posted on Jul 25, 2014
How do I replace my fsn motor on 1994 318i bmw
BMW BLOWER MOTOR RESISTOR FSU Replacing fan ...
? 1:26
www.youtube.com/watch?v=VwU-LRDzzUY
Feb 10, 2010 - Uploaded by Channel Zero Blower motor resistor switch. Intermittent fan when this part goes bad. air conditioner ...
Aug 04, 2015 | BMW Cars & Trucks
I have a 2001 bmw 325ci.. and it recently doesd not want to start..it sounds like it wants to turn over but dont..i changed the fuel filter on it and it has a brand new battery..and still wont start..i...
First check with a ob2 scanner for any codes like camshaft or crank sensor codes ...if u can find no codes then check and clean or replace air filter and clean mass air flow sensor using a electronic circuit cleaner and not a carb cleaner
Sep 05, 2013 | 2001 BMW 325Ci Position Sensor O-Ring
My 2005 bmw 325ci blows cold air sometimes than hot air what is the problem
if the air stays cold on one side and hot on the other side of the dash juxtaposed then it could be a sticking matrix door.
Aug 05, 2011 | BMW 325 Cars & Trucks
My air conditioner in my 2001 325ci does not blow air at all. What is the problem.
9 times out of the 10 it's the blower motor resistor in my experience. BMW uses an infinitely variable resistor that has a large heatsink attached to the back of it and they overheat.
Jun 19, 2011 | 2003 BMW 325
Replace altenator 2002 bmw 325ci
disconnect the negative battery. remove the belt by rotate the tensioner roller clockwise. from the left car side u will see three hexagon screw 13mm under the altenator. loose out the screw and remove the altenator. before that unplug the two wire behind the altenator.tq
Feb 28, 2010 | 2001 BMW 325
2002 BMW 325ci Power window, driver side button collapsed, nonop
unfortunately there is no way to "fix" that particular issue. the switch needs to be replaced.
Nov 08, 2009 | 1999 BMW 318 ti
Fuse box diagram for a 2004 BMW 325ci
Fuses & RelaysThe fuse box is located under the engine hood on the left side, near the upper strut housing or near the battery.
Various relays are also mounted on the fuse box for easy accessibility.
Flashers
The flashers are located behind the bottom center of the lower instrument trim panel.
Review the...
- BMW E36 Fuse Box Relay Layout
- 325ci Owners Manual
Hope helped.
Oct 23, 2009 | 2004 BMW 3 Series
Location of oil filter on a bmw 325ci 2003
You really cannot mis it. It is at the front of the engine, top center. Black can-shaped housing. Unscrew the top of the housing and replace the paper element inside.
Jun 18, 2009 | 2003 BMW 325
My air conditioner is not working on my 2002 BMW X-5. The air is cool it just won't blow out.
If there is air moving through the vents most likely the final stage transistor(blower resistor) has failed. It controls blower speed from a signal from the ihka (a/c control panel). the final stage receives the signal from the ihka of the drivers preference blower speed. the final stage pwm (pulse width modulates) the blower motor. which means it turns it off and on very quickly to speed up or slow down the blower motor speed. It isn't the easiest part to replace. Usually at a dealership i would expect to pay somewhere around $600 (including diagnosis)but don't hold me to it. bmw dealerships stand behind their repairs and usually include a warranty with the part of 2 years unlimited mileage.
May 07, 2009 | 2002 BMW 5 Series
Right door glass want go down all new parts 2000 325ci bmw
The window track is worn. This is a plastic strip that runs through a gear on the motor and raises and lowers the window. replace it.
Apr 23, 2009 | 2001 BMW 325
Motorsports Logo
149 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
