Home | Fujitsu | 18RC Air Conditioner | Airflow throughout House
Fujitsu 18RC Air Conditioner
Problem for Fujitsu 18RC Air Conditioner
By dorisanderwi on Jun 09, 2009
The inlet sits in the Hallway. Do we have to keep individual doors open when room is switched on for heating or cooling. Our unit is a R410A
Solution #1
posted on Jul 16, 2009
Not Rated)
matyt94
Rank: Guru
Rating: 87%, 28 votes
That depends on how big your system is and if you want the heated or cooled air to enter the other rooms. If there are entry/exit doors to the outside of the house, then these should be closed, along with windows, when the split system is operating.
Was this helpful?
Yes
No
Solution #2
posted on Jun 09, 2009
Not Rated)
spalm
Rank: Wiz
Rating: 82%, 36 votes
The system you have installed what is the kw cooling capacity? do you only have one evaporator installed?
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18RC Air Conditioner
Questions and Unsolved Problems for Fujitsu 18RC Air Conditioner
Do you recommend Fujitsu 18RC Air Conditioner?
Answer
Answer
I have a RHEEM AC unit and it's not coming on. What can it possible be?
Answer
need fan motor for inside unit for galanz split system airconditioner model AUS-18HR53FA2
Answer
how to set time and timer on ar-je5 remote control for fujitsu air conditioner
Answer
Serial signal reverse error code. Model ASTA09LCC. Unit was installed and ran for approx. 2 hours... (More)
Answer
How do I set the timer on a AR-JE5 unit I have lost the manual
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18RC Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
