Question about Pioneer AVH-P5700DVD Car DVD Player
How to install video bypass module?
I have a ford expedition.  I purchased a bybass module.  How do I install it?
0 characters
1 Points
Tb110 mw9 need to bypass remote with taking writing off screen
Since you are obviously Installing this unit on a boat!! (hint hint) Because it is Illegal to bypass on a vehicle! (due to driver's safety, to inhibit viewing while driving. Which end result would be possible DEATH) You can install a PAC TR-7 Which is a video bypass module. then you can view all the time w/o letters on screen. there avail on e-bay
Jun 14, 2014 | Car Video Players
Clarion nx700 parking break bypass
Wrong. To bypass the lockout feature so you can see the DVD play anytime - you need to toggle the green wire away from ground (from Low to High - i.e. momentary switch) so the radio sees the rising edge of the 12Vdc signal. The green wire is normally high and is tied low. When you put the parking break on - it opens the loop.
A switch will trigger the Opto Isolator inside the head and bypass the lock out feature. This works fine - or you can spend the $25 on the bypass module - that does the same thing - but works as an electronic toggle ~ based off the remote wire and an internal relay in the module. The module will toggle the green wire every time the radio powers up.
Jul 01, 2010 | Clarion NX700 Car Video Player
Help i need a wiring diagram for a pioneer avh-p5700dvd to connect to a wiring harness and a tr-7 output module
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
Jan 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
TV says locked out for your protection. how do I bypass that? Also how do i brighten the screen?
pac tr7 module will bypass the video lock. the lock comes on if you have the aux on while in drive. shuts off the screen so you cant watch movies and drive. go to amazon or google PAC-tr7 module. costs between 15-30 bucks depending on where you buy it. Very simple hook up, just follow the wire chart.
Nov 10, 2009 | Alpine CVA-1005 Car Video Player
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Video Players
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Factory controls interface?
Call these guys at and purchase the SWC module that matches your vehicle (ask for Scroche brand). Once you purchase the SWC module, make sure you read the installation instructions two or three times before you install it. Once installed, these SWC units work great. I just completed the installation on my 2008 F150 with the Kenwood DNX-7100 and my steering wheel interface works perfectly.
Feb 01, 2008 | Kenwood DNX7100 Car Video Player
Bypass code
What you need is a video bypass module and you can get it at
The module number is TR-7
Jan 26, 2008 | Car Video Players
I need to bypass the factory amp in my 97 ford expedition
the amp is in the rear panel pass side if you have the Mach sound system. There are 5 wires going into the amp and 2 going out to the sub.
Light Grn w/ Purple stripe is the 12v power (thick)
Blk w/ Grn Stripe is the grnd (thick)
Drk Grn w/ Pruple stripe is the remote (thin)
Red w/ blk stripe is sub high output +
Drk Brown with Orange is the high output -
Jan 09, 2008 | Car Video Players
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Pioneer AVH-P5700DVD Car DVD Player Logo
181 people viewed this question
Top Pioneer Car Video Players Experts
Craig Sagar
Level 1 Expert
Phil Sowers
Level 1 Expert
Are you a Pioneer Car Video Player Expert? Answer questions, earn points and help others
