Question about LaCie Rugged All-Terrain (301017) Hard Drive
Partition map check failed because no slices were found.
Harddrive not found
IDE or Sata lead fail check connections replace lead they do burn out. Are you getting Boot Mgr is missing? Partition needs altering if so, mini tool partition wizard...
Jul 26, 2014 | Dell Inspiron Computers & Internet
DMR-EH65 FAT32
You probably need to check the partition map format as well as the actual volume format.
One of the Options in Disk Utility lets you specify the partition map. Options include GPT, MBR and the classic Apple Partition Map.
The drive will need to be formatted as MBR in order to act like a 'true' PC disk. A FAT partition on a GPT disk isn't sufficient - it's still a GPT disk and that's what is confusing the player.
Custom Wheels For Honda
Jun 10, 2012 | Panasonic DMR-EH65 DVD Recorder/HDD...
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Dec 17, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
I just purchased an iomega ego /500gb and I'm having a problem formatting it by following their instructions. I just want to be able to plug it in and save my music. My mac doesn't even recognize it once...
You will need to format the drive to work with you Mac.
NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
9. Click OK.
Nov 21, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I use buffalo 1 TB external power hard disk on IMAC, it was work fine but now suddenly, when i copy any thing to it one error message came ''unexpected error--(error code 0)'' can't copy. please give me...
First when you attach it to your USB port it should come up as an external drive in any Finder window. If not then you need to run Disk Utility, found in Utilities in the Applications folder or just search in Finder for it. Select the external drive and make sure it says or and Partition Map Scheme : Apple Partition Map if it was formatted in 10.4 or earlier (you didn't say) or Partition Map Scheme : GUID Partition Table if formatted in 10.5 or later. If not formatted so, for example, it's Fat32, then it is set for a PC.
Assuming the last and that this is a new drive, you will need to format it for a Mac to be able to write. Select the Erase heading and for Format select Mac OS Extended (Journaled) in 10.5 or later or Apple Partition Map in earlier versions. Name the disk. Press Erase, knowing that the drive will be cleared of data. You can also choose to partition the disk, usually not needed nor desireable.
You can then return to First Aid and Repair Disk and after that Fix Permissions. If your disk had data already (you seem to say so) then this is where you would start making sure it says Write Status : Read/Write.
If the Partition Map is not as given above and thus the disk is read-only, then you will need to transfer the data to your internal or another external with the right map. -Ken
Apr 13, 2010 | Drive Computers & Internet
It says "no maps found"
I had the same problem before on a TomTom GO 730. The free internal memory was too small to hold the updated map so installation failed (the download to PC was OK, the message is misleading).
It's a TomTom software bug to not check on the available free memory properly before the update process is started.
My TomTom device required a new software install from scratch. Remove any excess MP3 or unused voices before you retry the update.
Feb 06, 2010 | Tomtom One XL GPS Receiver
No map available
It is quite likely that any maps you obtain from others will not work in your GPS as maps are coded back to component parts in the unit ANTI PIRACY codes .Similar to MS serial numbers. It reads ID's and checks against those stored in map. The only option is to purchase new maps for the area you want.
Jul 24, 2009 | Magellan RoadMate 800 GPS Receiver
About photoshop
20 Things About Photoshop You Have to Know
(Page 1 of 7 )
These are some of the tools and features that I find myself using on a regular basis when creating images for the web. These include using the slice tool on images to decrease page load times and using pre-set effects that save time when creating forms or menus for your site.Photoshop is, undeniably, one of the greatest software applications around. It has been around in one version or another for the last thirteen years, which is longer than I’ve known what CPU stands for. Currently in its eighth version, it has so many functions and features that I simply couldn’t live with myself if I didn’t explain the 20 most important and useful ones to you.
Layer Sets
These are a way of organising or categorising common or linked layers in the layers panel. To create a new layer set, expand the Layer menu and select New -> Layer set. The new layer set dialogue box will appear and prompt you to enter a name for the new set. Once you have OK’d this box, a folder icon will appear in the layers panel; just drag and drop related layers into this folder. This is useful to organise your working environment and to apply styles across ranges of layers. This functionality extends to slices in Imageready.
The Slice Tool
Residing in the toolbox that appears to the far left of your workspace, and denoted by the knife icon, the slice tool is essential for creating clickable rectangular regions of your image. It is powered by Photoshop’s sister product Imageready (which comes bundled with the latest release of Photoshop), and needs to be used in Imageready to make the most of its potential. Nevertheless, Photoshop lets you add actions when the region is rolled over or clicked, and can be extremely useful in the creation of roll-over image-swaps or expanding menus on image-driven web sites. To create a slice, select the slice tool and drag a rectangle across the appropriate part of your image. That’s it. You can right-click the slice and select Edit Slice Options… to add URL, ALT and other information to the slice. Slicing an image also decreases page load times; a couple of slices download quicker than one large image.
20 Things About Photoshop You Have to Know - Image Maps, Web Photo Gallery and Paste Into
(Page 2 of 7 )
Image Maps
Image maps are very similar to slices in that you can use them to create roll-overs and hyperlinks. The main differences between slices and image maps are that slices must be rectangular, but image maps can be any shape. They are used only in Imageready, and have no effect on image download times.
Web Photo Gallery
This time-saving function can be found under File -> Automate -> Web Photo Gallery… and can be used to quickly put together a high quality, gallery of images in HTML format. You simply select a source directory, a target directory, and let Photoshop do the rest. It creates as many web pages as needed to include all of the pictures in the source directory, which are presented in a tabular layout of thumbnails. Additional parameters such as page titles and ALT text can also be specified. It even makes each image clickable and loads the full size version of the image in a page of its own when the thumbnail is clicked! This can be used to quickly create a product catalogue or portfolio.
Paste Into
Accessed via the Edit menu, this function inserts an image into another image, and crops the inner image to make it appear as if inside the outer image. For example, you could draw a rounded rectangle 100 pixels wide and 20 pixels high and then draw another rounded rectangle 40 pixels wide and 20 pixels high directly on top of it. You could then use the magic wand tool to select the area inside the smaller rectangle, and paste a photograph into the selected area. Now only the area of the photograph within the smaller rectangle is visible. Combined with some text, this makes an excellent web page heading.
Perspective Function
This is grouped with other similar functions under the Edit -> Transform Path menu and is used to add, surprisingly, a perspective effect. It works best with angular images, but can also be used to add the appearance of movement. To use it, select the image you want to add perspective to and choose the function in the above menu. Your image will acquire a border with handles around the edge. Drag these handles in the appropriate direction to add the required amount of perspective. Click the tick at the far right of the tool bar at the top of the screen when done.
Plugins
Plugins are like applets that can be installed in the plugins directory and used to add functionality to Photoshop. If there’s something you’re trying to do in Photoshop that is remotely difficult, there is probably a plugin that will help you do it more easily. They can be downloaded from numerous sources on the Internet and are often free.
Styles
The styles panel is a repository of pre-set effects; if you draw a shape and then double-click one of the styles, those effects are automatically applied to your shape. There are a number of different categories of styles which can be selected by clicking the right-facing arrow at the top of the panel. There are a number of web styles including push buttons and roll-overs, and they can save you huge amounts of time when creating forms or menus for your site.
Dec 16, 2008 | Computers & Internet
LaCie Rugged All-Terrain (301017) Hard Drive Logo
162 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
