Question about Air Innovations Humidifiers
No mist coming out of humidifier
No mist coming out of the humidifier even tho the green light is on
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
  • 3 Answers
SOURCE: Honeywell Humidifier
The demineralzation cartaridge seems to be the issue. Remove it and see it the misting starts. If it does put a hole in the center cylinderical support of the demineralzation cartaridge, the one that fits over the white positioning post that is built into the base of the humidifier. This will allow the cartirdge to sink to the bottom and not interfer with the water tank plunger opening up and filling the base.I opened the hole completly but I think a smaller hole will do.
Posted on Mar 16, 2008
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
  • 8 Answers
SOURCE: humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
Posted on Jul 03, 2009
  • 114 Answers
SOURCE: WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Posted on Aug 20, 2009
Testimonial: "Thank you for your respond. It was very helpful."
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
My humidifier is not working. It is on but the light is orange instead of green. No mist is coming out.
There is probably a calcium buildup in the lines from the tank to the humidifier. You will need to take it apart to lean it. 50/50 White Vinegar should do the trick, Then flush the system with clean water, before using it as a humidifier again. In the future try using Bottled Spring Water or Distilled Water instead of tap water. Especially if your source of water is a well.
Feb 06, 2011 | Vicks V745A 1 Gallon Humidifier
No mist is coming out of it but the green light is on.
Hi Lisa,
  • Check that there is water in the Water Tank.
  •  Make sure that nothing blocks the Mist Output Slots.
  •  Check that the Fan Vent on the bottom of the humidifier is not blocked.
  •  Empty the humidifier and rinse the Water Basin with cool tap water and allow to dry for 15 to 30 minutes before resuming normal operation.
  •  Check for possible mineral deposits on the Water Level Sensor or the Nebulizer.
For more information, check out the owner's manual here. It is truly helpful!
Good Luck!
Nov 03, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
1835 Ferry Road
Jan 28, 2008 | Crane Cow Humidifier
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Humidifiers Logo
67 people viewed this question
Top Air Innovations Humidifiers Experts
Mack Baxter
Dennis
Are you an Air Innovations Humidifier Expert? Answer questions, earn points and help others
