Question about Stoves 1100ESIDLa Electric Kitchen Range
How do u replace the buld in oven
How do u open the bulb cover to get to the bulb ?
  • 363 Answers
Try unscrewing the cover.
Grasp the glass cover and twist it anti-clockwise.
Posted on Oct 27, 2007
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
How do I replace bulb in oven? Stoves el716 what is bulb part order number?
you can remove the bulb first then go to the local pound shop or a hardware shop or even morrisons or tesco the buld will be a standard screw in but has to be an oven buld not a normal one ive found these bulbs in the local shops easily do not use any unhardened buld for the oven type i replaced one the other day as usual i got a pack of two from the local hardware guy for a couple of quid
Oct 18, 2014 | Ovens
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
Can't remove the oven light bulb
if the bulb was screwed in to tight, you need to unplug the stove.. put on some protective gloves ... now spray some lubricant the socket... let stand for a few minutes.. the bulb might break!!! when you try to unscrew it. try to unscrew the buld by turning the buld right to left this will work in the lubricant. when you feel it getting easier to turn, you can finish taking the bulb out.. some stoves have a cover on them. these may require a flat head screwdriver ,a phillips screwdriver or a quater inch nutdriver ect... or a cover retainer clip .. remove the screws or clip then replace the bulb... UNPLUG THE STOVE ! ! !
Good luck
Oct 10, 2009 | Kenmore Kitchen Ranges
Double Oven Bulb is stuck in socket
The best thing to do is to grip the bulb with a pair of grips with a cloth rond the bulb and try twisting it out that way.
Don't worry if you break the bulb as all you have to do then is twist the remains of the bulb base out with a thin pair of grips..
You can safley spray it with WD40 , it is not a fire risk..
PLEASE ENSUREN YOU HAVE THE POWER OFF.
Plz rate my solution,and feel free to leave antycomments.
Thanks.
Jan 03, 2009 | Bosch HBN 3550 Electric Single Oven
OVEN BULB COVER
It should just turn counterclockwise to come off.  Sometimes it is very hard to turn them.  If you have a strap wrench you could try that.
Oct 19, 2007 | Cooktops
Stoves 1100ESIDLa Electric Kitchen Range Logo
114 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
