Question about Bias SoundSoap Pro 2 for PC, Mac
SoundSoap Pro 2 serial - Bias SoundSoap Pro 2 for PC, Mac
What does u3101 class two short to battery mean
The code is U1301 not 3101 ! This is a code for the class 2 serial data bus , the modules on this vehicle all communicate , share information on this data bus ! If you don't know anything about multiplexing or data bus communications you need to take this to a pro who does !
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. In addition to this, Node Alive (State of Health) messages are transmitted by each module on the class 2 serial data circuit about once every two seconds. When the module detects no messages and a high voltage on the class 2 serial data circuit for approximately three seconds, U1301 is set and the setting of all other class 2 serial communication DTCs is inhibited.
Feb 24, 2015 | Cars & Trucks
Mac Book Pro Serial number W86500Z4W0M when was it manufactured
Mac Serial Number Lookup All Info Query.
http://www.appleserialnumberinfo.com/Desktop/index.php
Serial Number: W86500Z4W0M Model: - MacBook Pro (17-inch Core 2 Duo) (CTO) Codename: - No codename assigned. Build Country: - This unit was built in Changhai, China. Build Year: - This unit was built in 2006. Build Week - Your Mac was built in week 50 of that year (December). Production Nr.: - This unit was number 1126 to be built that week.
Sep 28, 2014 | Computers & Internet
Serial number
I do not have serial for acid pro 7.0 i can`t work with it please sent me the serial number
Dec 17, 2013 | Sony ACID Pro 7 for PC
Serial photomatix pro 4.2.7
Hello, here is download link http://downloadity.net/0T78678 for Photomatix Pro 5.0.1 incl. Activation Key. With this Serial Key you can get full and free Photomatix Pro 5
Enjoy. Photomatix Pro 5 Serial Key Free Full Photomatix Pro 5 0 1
Aug 20, 2013 | Nik HDR Efex Pro
Authentication code sound forge pro 10.0
serial for Sound Forge pro 10164-41PJ-D3SJ-1LK6
Authentication code
D1WYYWZG6-B60EB12XN-QYQXY55RQ-4KXSPFKXK-ZK5P7Y1TE-HZ5941KRY
Apr 16, 2012 | Sony Sound Forge Pro 10 for PC
I Have a Canopus Dvstorm2 Pro But I Lost my Software Cds Please help me I Want The Drivers Pack That Run In Adobe Premier Pro 2
Hi Ali,
You can download the driver for your graphic card on the link below:
http://www.canopus.com.tw/UP/DVStorm/DVStorm-Driver.php
Oct 28, 2010 | Canopus DVStorm2 Pro (Bundle) Graphic Card
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
Bias SoundSoap Pro 2 for PC, Mac Logo
Top Bias Computers & Internet Experts
David Payne
David Payne
Are you a Bias Computer and Internet Expert? Answer questions, earn points and help others
