Question about HP Computers & Internet
Install a second hard drive to my hp pavilion p2-1310
  • 21 Answers
SOURCE: seagate hard drive
the seagate hard drive is for a desktop, this will not fit a laptop
Posted on Mar 24, 2009
  • 1170 Answers
SOURCE: remove hard drive
Here is a tutorial : http://www.ehow.com/how_4425468_remove-hard-drive.html
Posted on May 11, 2009
  • 334 Answers
SOURCE: swapped hard drives, wifi doesn't work now.
Hey there, go to the following link and tr to reinstall the driver. just enter your model numer (ie dv9074cl) then enter your operating system then it will bring up every driver for that laptop. Make sure you blow out the top left corner slots with canned air on a regular basis with these hp's or they will overheat and eventualy fail. Very important, the are notorious for this. Let me know if you need any thing else
seth
Posted on Jun 27, 2009
  • 597 Answers
SOURCE: HP Pavilion dv1000: hard-drive wont load OS
The arm that controls the head has malfunctioned. Your hard drive is probably toast. The more you run it though the more chance you have of not being able to recover the data on it. I have a Tip and Trick for trying to recover some of the data. You can read it here.
Please share it with your friends.
http://www.fixya.com/support/r3584465-bad_hard_drives_and_data_recovery
Posted on Dec 06, 2009
Testimonial: "useful tip"
Wins411
  • 166 Answers
SOURCE: Can I install a hard drive in an HP Pavilion 6736
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
Posted on May 04, 2010
Testimonial: "Helpful..!!!"
Remove hard drive from HP Pavilions a6230n
No you have to remove the media drive cage from the front the panel comes off. then pull on green tab to remove it completely then you'll be able to reach the harddrive
Dec 06, 2012 | HP PAVILION A6230N DESKTOP PC
02-07 Fail HP Pavilion dv9000 Installed a brand new hard drive, Same error.
get all your information you need off of the HD and reinstall windows see if that will get rid of the problem.
Dec 13, 2011 | Computers & Internet
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
I have the above system - HP Pavilion dv9933cl. Came with Vista. I scrapped this, flattened the drive and upon attempting to install XP Pro...am dealing with the "hard drive not found". Been searching and...
The newer systems do have to have drivers for everything. The best way to do this is to reinstall Vista, it has a hard drive manager built in and you can cut the hard drive in half or cut it as big or as asmall as you want. Then install XP on the second half install a boot up manager and have two systems on one computer, this is how i did mine. I used Vista till I got My Xp running like I wanted and I use Vista very little now.
Jan 14, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
No caddy for hdd hp pav ze4540
goto ebay.com and find the hdd caddy online .. order the full kit to install a drive or second hard drive
Sep 28, 2009 | HP Pavilion ze4540 PC Notebook
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
PARTIONING HARD DRIVE
Make it slave and attach to the machine. If it is SATA, then attach it normally and change the boot order in BIOS.
Apr 11, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
