Question about Pulsar Chronograph Watch
How do i find out how old my watch iis
141508 is stamped on back, and i could not get the back off.
What type of battery fits my watch?
The battery size may be stamped on the back of the watch. Jewelry counters that sell batteries will determine the size and even change it for you. If you are a bit mechanical you can remove the back, mine has little screws but often it is one you pry open with a thin screw driver. You will then see the battery but don't move it until you make note which side is up. The size is stamped on it. Put the new battery in facing the way the old one was and close the cover.
Apr 27, 2015 | Watches
Watch battery replacement
Radio shack has TONS of batteries, if they don't have it in stock, they can get it
Nov 08, 2013 | Watches
I have an old fossil bq-8793, years ago I was going to replace the battery myself. I lost the battery back then, there seems to be no indication on the watch itself as to what size it takes inside or out....
Back Plate:
About 1 1/4'' inches wide. Inside inscription/stamp reads:
FOSSIL INC. HONG KONG 1
Battery:
Energizer 373
Movement plate:
There are 3 inscriptions/stamps
1) S (May be a # 5)
2) 1A
3) TMI TIME MODULE INC. JAPAN VX3J
(The above number stamp may also read UX3J)
Mar 29, 2011 | Watches
What battery do i use for cl-5009
The only way to know what size is to pull out the old one unless it is stamped on the back of the watch, or is in the manual. Sorry.
Aug 30, 2010 | Columbia Sportswear Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Need to find the value of an old Piaget watch that I inherited. The numbers on the back are stamped as follows: 6801 E 10 228916 the band says Piaget 750 thanks Rani
mcdevito75 Here, Hello Rani, Piaget, a FINE watch, even without seeing your Piaget watch were speaking $250.00 and above. Shop a couple of jewelery shops in your area, they will be glad to help. NOTE-- unless you relly know, DO NOT CLEAN THAT PIAGET YOURSELF as any Damage could and would leesen it"s value. By cleaning I mean even polishing the band, have a small watch repair shop in your area care for your Piaget watch.
Jul 07, 2010 | Watches
My sekonda pocket watch is stamped au 10
My pocket watch is stamped Elgin.
We are sure yours is very nice.
May 12, 2010 | Watches
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Pulsar Chronograph Watch Logo
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
lessaleadr
Level 1 Expert
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
