Question about Black & Decker CG800 Food Processor
Grinding bowl (Part # CG800-01)
Where can i get this part as my Bowl has started to crack
4 Suggested Answers
Cuisinexpert
  • 61 Answers
SOURCE: MY food processor has a cracked bowl assembly and
Contact the manufacturer. Most retail stores will not sell parts like this (and if they do, it's probably a store that will be something like a kitchen specialty store--aka, a little more pricey), so the best way to go is to contact them directly so that they can get it for you (and, a lot of times, they can get it for you at a cheaper price, or, if you're under warranty, sometimes for FREE!!).
Their contact number should be either stamped somewhere on the machine (usually on the bottom--might be stamped directly into the plastic, so make sure you have it in really good light when trying to read) or in the product manual (usually near the back of the book).
Good luck! :)
Posted on Aug 22, 2009
SOURCE: Need replacement bowl for Black & Decker Food Processor CFP10
I have the same machine. I need a disc stem which is no longer available. I will throw away this appliance. If you want your missing part. I can send you mine. Pease email me at Sotiris.Korovesis@yahoo.com.
Posted on Oct 26, 2011
SOURCE: Black & Decker F1 CFP 10 food processor bowl cracked
I have all the parts B & D Shortcut Food Processor CFP-10 but a dead motor today. Send me your contact info and I will mail to you the parts.sheila
Posted on Jan 05, 2012
GE 14-cup digital food processor; bowl cracked, either by lid fastening or ice cubes in the bowl while chopping mode; don't know exactly. Is this covered by warranty ? Or are separate bowls available...
how old is your processor? did you buy an additional warranty when you purchased it? If so you should read the paperwork. Whats covered,and not, should be listed. you can probably buy a replacement bowl for it on the website.
May 11, 2011 | GE Food Processors
Replacement Bowl for Kenmore Food Processor Model #69703
check with marbeck.com. I am almost sure the cuicannart parts they sell will fit this model under model DLC_7
Sep 09, 2009 | Kenmore KFP-70 Food Processor
Hamilton Beach food processor, model 70450, cracked bowl
You have a couple of choices here. The quickest and cheapest is to go to the hardware store, or a home depot and get a tube of one minute clear epoxy. This adhesive will repair the crack and since it is clear it will barely show. Plus it will dry in just one minute.
That said, yhou could also go to hamiltonbeach.com and get a new part.
Jul 11, 2009 | Hamilton Beach 70450 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Does anyone want to SELL me their Black & Decker Shortcut Food Process that they cannot get parts for? s.lamos@comcast.net
Jan 25, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Black & Decker CG800 Food Processor Logo
Top Black & Decker Food Processors Experts
Holly...
Holly...
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
