Question about Wurlitzer Audio Players & Recorders
Error code 47
How do I clear it, and it is throwing cds
Airbad error code 47
For a 99 626, the service information says that code '7' is for the passenger side airbag module. I know that your question says that you have a code '47', but the information has codes 1 / 2 / 3 / 6 / 7 / 11 / 12. It states "replace SAS module for codes not listed." The SAS module is the main airbag computer.
Jan 12, 2014 | 1999 Mazda 626
2004 Toyota Solara getting error-1 code on cd changer.
you can use MVCI check your car. and clear the fault code.
Jun 27, 2012 | 2004 Toyota Solara
Cannot get license, because server send error code:47-ncomputing
Cannot get license, because server send error...47
what is solustion this prbloems
Jan 31, 2011 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Ir6000 error code e246-0002
fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Cannot get license, because server returns error code:-47 NComputing Error
Nov 18, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Tv will not turn on
If the led doesnt blink, That would indicate that its going to have to be extesively diagnosed by a technician to determine the problem. I would guess that its a regulator in the standy by supplies since anything else should throw an error code.
Dec 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
27 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
