Question about Toshiba TP55H60 55" Rear Projection Television
I'm having problems with my toshiba
The symptoms are when I push the power button the tv makes noise like it is going to show then it shuts off in 2 seconds the hole dcreen is blue,when I unplug it and plug it back up it gives off a big spark.
    Champion:
  • 317 Answers
Call tech ..suggest blue tube.
Posted on Nov 26, 2007
Toshiba 37C3030D 37 panel lock
It is very likely that there is a power supply failure
Mar 01, 2013 | Toshiba 37C3030D 37 in. LCD Television
Whole screen has gone blurry with the red and blue showing 3 images together side by side
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 18, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba 50HDX82 projection TV has started intermittently going black, still has sound, or looks like a 3D image (minus the glasses to see it right) and last night the power led on the front started...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 21, 2011 | Toshiba 50HDX82 50" Rear Projection...
Picture showing double. Red color is warped.
  • Screen looks 3D
Here are some images of convergence problems.
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Nov 25, 2010 | Toshiba 43H71 43" Rear Projection...
Toshiba 32A42A - Menu options pop up all by themself, and the TV is making its own choices. Can this be fixed or do I call a Preist for an exercism or just get rid of it ?
I had the exact same problem yesterday. It took me 1 hour and 45 minutes to find a solution. Here is the solution: It is not a stuck button or the television being 'posessed' that is resulting in the menu cycling. It is the fact that the television is in the DEMO mode. I was able to read the manual for this television online at the Toshiba website. On page 30 it states 'To stop the DEMO mode press 'recall', ''exit', or 'power'. Unfortunately the 'recall', and 'exit' button are on the original remote which I no longer have. The power button on my model is broken. I use the cable box to 'turn on the television'. In reality, the TV is never off, it is just showing a black screen when the cable box and DVD player is off. I suspect this defect in the power button has occured on other TV's experiencing this problem. I was able to push the broken power button to the inside and side of the television casing exposing a round circle that the power button pushes when the power button is not broken. I pushed this small circle to turn the television off. After about 5 seconds I pushed the button again and the television went on without the annoying menu popping up. Just unplugging the television and plugging the television back in does not work. You need to be able to push the power button, or one of the other 2 buttons on the remote previously mentioned.
Also on page 30 it explains how to activate the DEMO mode. It's not too hard to accidentally do, especially when you have kids pushing buttons haphazardly.
I hope this helps someone outthere in cyberspace! Kevin
Sep 20, 2010 | Toshiba Televison & Video
Toshiba satellite P205-S6287 the power button
Make sure the battery has a full charge, and that it's plugged into a wall socket, then try the power button. You will get the same symptoms as a bad power switch if your battery power is very low. Other than that, the battery could be bad, or going bad. If the problem is a faulty power switch, you will have to have it replaced.
Mar 12, 2010 | Toshiba Satellite P205-S6287 Notebook PC
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
Noise from the back
Its your light engine going out and it will cost you anywhere from $700 to $1000 to fix it. Save the lamp and find a cliff to push it over when it goes. There really ought to be a class action suite against Toshiba for selling such an piece of ****.
Aug 30, 2008 | Toshiba 52HM95 52" HDTV Projection...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Toshiba TP55H60 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
