Question about RCA Televison & Video
How to Adjust the impulse phase on rca led tv
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Purchased a Sanyo LED 50" 1080p HDTV LCD,was told if I also purchase Roku 2,..this will turn my Sanyo into a SMART TV HOW DO i make that happen?
My first impulse is to tell you to go back to the store, admit you didn't understand what you bought and ask them to teach you.
My second impulse is to tell you to Go to Roku's site and read how to do it.
I have no third impulse.
Apr 12, 2014 | Televison & Video
I need info about what the cpu phase leds on aN msi 990fxagd65 mean
They indicate the number of different power phases that the CPU is currently using. In order to save power the motherboard is able to reduce the voltage to (and performance of) the CPU. In 2 phase mode (2 LEDs) it basically switches between high performance, and low performance. 4 LEDs means that there are two additional intervals in between the high and low power settings. 6 LEDs indicate six total phases, etc.
I believe that there is a greater possibility of system instability as you increase the number of phases that the motherboard switches through.
Oct 22, 2012 | MSI 990fxa-gd65 Motherboard Am3 Amd990fx...
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
Jul 13, 2012 | RCA Televison & Video
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
Televison & Video Logo
123 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
