Question about Ricoh Aficio MP2352 Copier
Drum is getting to hot - Ricoh Aficio MP2352 Copier
  • 48 Answers
The drum is situated right below the fuser/fixing unit which stays at a high temperature during use, after a while it will warm up the drum as well, you are not supposed to touch the drum, if you feel it is getting abnormally hot, then contact a qualified technician to investigate
Posted on May 05, 2014
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Kenmore 80 series the drum will not turn but dryer gets hot
more then likely, the belt broke that turns the drum.
Jan 24, 2012 | Kenmore Dryers
I have a DCP-7040 Brother Laser printer. I am getting a lot of black lines when i print. I have tried cleaning the head of drum but that did nothing.
Two likely possibilities:
1. The drum is scratched by particles caught under the drum cleaning blade. Every copier or printer that has a drum leaves a little bit of toner on the drum that didn't get transferred to the paper. A soft plastic blade scrapes off that excess. If a chunk of fused toner or something gets caught under it, it can scrape a groove around the drum, resulting in a black line. Take a close look at the drum for scratches matching the lines you get. The cure is a new drum unit.
2. The fuser roller is scratched. Open up the back of the printer. The fuser is the assembly with labels warning about how hot it is. The final stage of the print process is to press the page between those two hot rollers, melting the toner into the paper. The hot roller is coated with Teflon to prevent pulling toner off the page and laying it back down where it doesn't belong, but like the drum, it can be scratched. You might be able to look for scratches on the hot roller with the help of a strong flashlight and magnifier. If it's scratched, you need a new hot roller or a complete new fuser.
Let us know what you find.
Apr 21, 2010 | Brother DCP-7040 Laser Printer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Heating element is hot, but, no heat in drum.
disconnect the duck pip from the back of your unit and see if it is hot inside... if it is getting hot then your pip need to be clean.
if it is still the same your drum have felts in the front and the back that go bad, the heat is leak from the drum sides.
Jan 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer gets hot but the drum does not turn
sir please check the motor is running and this will be fixed inside the dryer and a belt will be fixed which makes the drum to rotate when the motor starts.so you should check both the belt and the motor.
Sep 04, 2009 | Hotpoint Aquarius WD640 Front Load...
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
Rear brakes 2000 ford focus zts
emergancy brake cable is froze holding the brake on
Mar 20, 2009 | 2000 Ford Focus
Ricoh Aficio MP2352 Copier Logo
14 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
