Question about Husqvarna/jonsered 136-142,2036-2137 Clutch
Dont wont to start to much fuel in cilinder
In primimg pips have air and dont wont start
    Master:
  • Husqvarna Master
  • 645 Answers
Never pull the starter more than 3-4 times under full choke. Pull 3-4 times on choke, push in to half choke and pull, should start.
Posted on Feb 03, 2016
I did a 98-350 chevy swap to a 98 jeep wrangler. It starts and then stops after about 2 seconds.I think the security system in the ECM is shutting down & not letting the injectors fire. Is there a way to...
asd is shutting down the fuel sounds like 2 seconds is the inatal fuel supply for primimg check the asd relay and the 15 amp asd fuse should have power only when enginge is turning or running
Oct 04, 2013 | 1998 Jeep Wrangler
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
1977 yz80 wont start. Cleaned carburetor, checked magneto, but cant get to start having problems getting spark, replaced plug.
If you have a spark, but weak. It is possible that your flywheel is demagnetised. Then you'll need a spare.
If sparks are good, then the spark plug should be moisted with fuel after a few ( 10 ) choke kickstarts. If so you'll have a weak compression. Then you have to at least clean out the piston ring grooves ( dismount cilinderhead and cilinder ), or even change the piston rings or overbore the cilinder and place a new oversize piston kit.
If spark plug stays dry when kickstarting, the carburettor is faulty. Clean it out, check also the choke system. Check the air intake between carb and cilinder for air leaks.
Oct 04, 2009 | Yamaha YZ 125 Motorcycles
My nissan 300 zx cilinder 2,4,6 over fuel and dont work pleas help
have your fuel pressure tested as the fuel regulator can be defective this regulates the fuel pressure in the system. check that the return fuel line is not blocked. disconnect the cold start injector when starting and this ilimunate over fueling non start up.
Jul 23, 2009 | 1990 Nissan 300ZX
Bike has no power up to 7000 rpm
check your gear ratio ie chain and sprokets if thay are to high of a ratio this will happen . as these bikes dont start to make power untill thay rev up hight . thay are tuned for top end revs and speed
May 31, 2009 | 1990 Suzuki RGV 250 L
Wont start
Hi
First check compression.Priming the engine for few times.Check the air and fuel filters.Check the flyweel keey not to be shatered off(timing).Start the engine.If the engine only runs the gas from the cilinder you puted inside you have a fuel delivery problem to find and fix.The spark at the plug has to be blue!
best regards savumihai71
Jan 16, 2009 | Briggs & Stratton Prosumer 20324 Gas...
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Loss of power
Do you know how check if every cilinder is working? with the engine in idle, go to the distribuitor cap and carefully unplug one at the time, every cilinder spark plug wire,in the cilinder you dont see a diference in rpm variation, that cilinder is not working, replace spark plug, if you see spark jumping fron the distribuitor cap torch the spark plug wire, another cause to a cilinder fail could be a loss of compression in one or more cilinder
Oct 29, 2008 | 1994 Toyota Pickup
I have a 88 tunderbird and it wont start
it could be the pip sensor or crank sensor in the distributer if it has fire on the wires check the injectors for power to see if theyre workin
Jun 24, 2008 | 1988 Ford Thunderbird
Husqvarna/jonsered 136-142,2036-2137 Clutch Logo
56 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
