Question about Ovens
My zanussi zcg551gwc keeps tripping the fuse oven light not working neither is the electronic ignition
  • 1462 Answers
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Posted on Jan 06, 2009
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
farfield
  • 462 Answers
SOURCE: oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Posted on Mar 12, 2009
barkencoa
  • 3463 Answers
SOURCE: zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Zaunssi ZBF360X built in Oven Not Heating
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Zanussi 360 just tripped and now keeps tripping
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
