Question about Yamaha Restio ISX-800 Floor-Standing Style Desktop Audio System
Not playing CD's - Yamaha Restio ISX-800 Floor-Standing Style Desktop Audio System
How do I play a cd on the radio
Press the eject button and insert a CD. Press the CD mode button and press Play. Usually, when you insert a CD, it will start playing automatically.
Jan 25, 2016 | Cars & Trucks
Why will my xbox let me play some games but not other on live when i used to be able to play them all?
Check all X Box games for scratches on the surface of each CD Disk.
Keep in mind, each game CD is read by lens Laser from the inner then to the outer edge of CD Disk.
Most people believe CD's are played like a record, from the outer edge to the inner.
If there are scratches, CD may be damaged beyond simply cleaning.
All cleaners and methods of cleaning are not the same.
Contact the manufacture of the CD to find out the best method of cleaning
or possibly repairing so game can be played.
If you CAN play some games and NOT others, this rules out a Laser Lens Player fault condition. Look for a reason of the CD will not play in the Laser Lens Player.
Here is the top 5 reasons CD's will NOT play.
1.) CD in inserted into player wrong way?.
2.) CD surface is dirty or dusty?.
3.) CD is possibly warped or bent?.
4.) CD surface is scratched?.
5.) Wrong CD/ or format for CD player?.
Hope this lists helps!
FASTESTNASCAR
Jan 01, 2012 | Microsoft Xbox 360 Console
Magnavox AZ9855 mini system (7 CD changer), trying to play a cd, the system ejects the CD and message Failed CD is shown. No CD will play.
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Oct 06, 2010 | Audio Players & Recorders
When I burn a music cd it will not play in my sterio or cd player, it only plays on the laptop. Can you tell me what to do to fix this.
Make sure the players can play the format you are using to burn. My surround sound system will play most audio but my car system will only play an origional cd format (AU) not mp3 or wav for example. Also some systems will not play cd-rw but will play cd-r and some won't play anything but origional cd's.
Aug 03, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Emachine W6409. will play cd. will not play dvd.
sounds to me like you have a cd-rom drive and not a cd-r/dvd rom drive? are you sure it is a cd-r/dvd rom drive? If its not it won't play DVD's because CD drives use a different codec than DVD rom drives do. CD-r/dvd drive combos use the same codec though as one.
Jun 06, 2009 | E-Machines emachines (emachinees) CD-ROM...
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Mar 05, 2009 | Wurlitzer Jukebox CD Player
CD won't play
Sounds like the disk has not finalised correctly. Computers can play CDRs when they are only partly completed as they search the disk fro the files. A CD player expects to find a Table of Contents to tell it where the tracks are and if this has not written correctly it will not play on ordinary CD players but will work in computers.
Regards, Andrew
Sep 11, 2008 | Audio Players & Recorders
A copied CD why will it not play in a certain make of car
It is probably because the CD player in that car will not play Cd's recorded on a computer or home CD recorder. There are lots of CD players out there like that still. You will need to get a car stereo that plays CD-R and CD-RW. That is the only solution.
Jun 29, 2008 | NAD L40 CD Player
Yamaha Restio ISX-800 Floor-Standing Style Desktop Audio System Logo
20 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
