Question about Dell Vostro 200 PC Desktop
What does four beeps mean for vostro 200
Trying to turn on my computer and all it does is beep four times?
byteguy
  • 2229 Answers
SOURCE: Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Posted on Feb 01, 2009
  • 90 Answers
SOURCE: won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Posted on Apr 20, 2009
SOURCE: 4 short beeps on vostro 200 monitor shows black?
this is a BIOS problem (that's the software on your motherboard, in the computer rarther than the monitor). the 4 short beeps are an error code which you can look up on the dell support website.
i just searched for:
http://www.google.com/search?q=dell+vostro+200+bios+error+codes
and it found:
http://support.dell.com/support/edocs/systems/vos200/en/slim_tower/om_en/pdf/PK009A01.pdf
check page 80: beep codes
which will tell you that 4 beeps indidcate an error with your memory (RAM).
Posted on Aug 09, 2009
bob_computer
  • 3153 Answers
SOURCE: dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 05, 2009
  • 5384 Answers
SOURCE: Vostro 200 won't go to startup
The 4 beeps suggests a memory issue. If you open the case and pop the memory modules out and then reinsert them it may clear the problem. One way to check if an individual memory stick is bad is to reboot as you put them in one by one.
I hope this helps.
Posted on Jan 03, 2010
2 beep after 4 second 2 beep again and again 2 beep
Probably RAM issue. Try reseating the RAM sticks, if that doesn't work, remove one at a time and turning on PC.
If you only have one RAM stick, then it could be faulty, so if you can borrow or have access to another RAM stick, then try that.
Jan 19, 2014 | Dell Vostro 200 PC Desktop
Why does my Dell Vostro 200 keep beeping?
Defective memory can cause blue screens, no video, beeping sounds. It's possible that you have a defective memory stick.
May 24, 2012 | Dell Vostro 200 PC Desktop
Vostro 200 four beeps at startup then repeats; fan stays on.
Cant say for sure what the problem is, but most probably it is due to a bad RAM module. Try removing it and after removing the dust on the RAM and its slot Re-insert it. Also try cleaning up other areas with a blower too. It should workout.
May 28, 2010 | Dell Vostro 200 PC Desktop
I hope this helps.
Jan 03, 2010 | Dell Vostro 200 PC Desktop
Pc beeps 4times y?
4 short beeps
Your problem could
be a bad timer. The system timer failed to work properly. It will
require motherboard replacement.
1 long and 3 short beeps
Memory test failure. An error has been detected
in the memory over the first 64K. Try replacing the memory, and if
that doesn’t do it, the motherboard.
Beep codes are the beeps you hear from the
PC speaker when you turn on your computer. They are your computer’s way of letting you know what’s going on when there is no video signal. These codes are programmed into the BIOS of the PC.
Nov 10, 2009 | Dell Vostro 200 Desktop Computer
My computer beeps 4 times
i don't rememer perfectly, but 4 beeps, i think is loose video card,, or loose menory in its slot, take cover off of it, and reseat one at a time, then restart with power, it's one of them, mem or video card loose
Nov 02, 2009 | Dell Vostro 200 Desktop Computer
Dell vostro 200 4 repeated beeps on start up
Beep codes Pc
More beep codes
Oct 05, 2009 | Dell Vostro 200 PC Desktop
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
Apr 20, 2009 | Dell Vostro 200 PC Desktop
Dell Vostro 200 PC Desktop Logo
46 people viewed this question
Alun Cox
