Question about Innovera 16010 16010 One-Color Printing Calculator, 12-Digit LCD, Black IVR16010 IVR 16010
My calculator wont stop printing
I don't know how to turn off the print function
CALCULATOR WONT PRINT
What make of camera includes a calculator ?
Aug 19, 2016 | Cameras
How to turn print function off
Press 2nd [P/NP] to switch between print and non-print modes. See page 2 of this manual.
Jan 14, 2013 | Sharp EL-1611P Calculator
My laptop prints blank pages no matter what I print or what kind of file. The printer is an HP all in one. I've uninstalled and reinstalled the drivers. Didn't work. The prints by itself just...
This looks like a DEP problem (Data execution Prevention) which is part of Service Pack 2 (SP2) on your computer. To solve the problem, DEP needs to be set on: DEP only for critical windows programs and services (I don't know if this is the correct translation). You will find the DEP settings on your windows help function. .
Jul 01, 2011 | Samsung ML 1710 Laser Printer
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
Calculator still functions, but printer is not printing anything but nonsensical giberish. Canon P200-DH III
Try pulling batteries/power /out/off.look for reset hole usually a very small hole on back. push in with pin.reinstall batteries (check they are good)or use new,if power adapter plug in turn on try to print.These instructions are genetic not specifically for your model. The printing issue you describe is typically a glitch in the program.
Jan 04, 2011 | Canon P200-DHIII Calculator
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
I have a Sharp EL-1701C Calculator
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
Apr 15, 2009 | Sharp EL-1701C Calculator
Printer malfunction
I"m having the same problem. Just started this morning when I turned my calculator on. Any suggestions?
Nov 08, 2007 | Sharp EL-1197P Calculator
Printing
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
Innovera 16010 16010 One-Color Printing Calculator, 12-Digit LCD, Black IVR16010 IVR 16010 Logo
Top Innovera Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Innovera Office Equipment and Supply Expert? Answer questions, earn points and help others
