Question about Music
How do you adjust the intonation on a washburn 2001 series wammy bar
3 Suggested Answers
  • 30 Answers
SOURCE: i need to know how
i agree with shiming the nut bridge, but if you ABSOLUTLEY have to adjust it: on the head stock exactly behind the nut bridge there should be a piece of plastic with 3 little srews. remove them and you should see a allen wrench head that is used to adjust the truss rod if you want to tighten, rotate allen head NO MORE THAN A QTR TURN to the right, make sure you let this set for at least 24-48 (preferably 48 so you can let the neck settle) hrs before adjusting another qtr turn if needed.
Posted on Jan 24, 2010
  • 94 Answers
SOURCE: how to adjust the truss
READ MANUAL IT CAME IT MAY HELP YOU ADJUST TRUSS BAR.
Posted on Dec 22, 2010
Washburn mercury series electric serial #6050208 trying to find out what I can about it. Found it in a dumpster dive.
Cameron, nice find. Check the attached links,instruction and guides, you can also Google or Bing search the guitar for more info. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.washburn.com/media/catalogs/pdf/Washburn1993ElectricsCatalog.pdf
Blue Book of Electric Guitar Values ELECTRIC MERCURY SERIES ELECTRIC...
washburn mercury series electric guitar Google Search
WASHBURN MERCURY SERIES guitar list
Jul 08, 2016 | Washburn Music
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
I have an old JB Player electric guitar. It has a wammy bar (black). Anyway the part that the wammy bar goes into that holds the strings down at the bottom of the guitar is not good any more. I think...
i am not familiar with that guitar. But if it's a strat style guitar you can get the springs here....
http://www.stewmac.com/shop/Bridges,_tailpieces/Electric_guitar_tremolo_parts/Tremolo_Tension_Spring.html?actn=100101&xst=3&xsr=4684
You can try just adding a spring or replacing all of them....
Mar 08, 2010 | Jb Player Music
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
We need to replace a broken tuning peg for a Washburn D10SB series acoustic guitar . Where can we get them from?
Almost any guitar store would have this and any Luthier would likely have a replacement.
Washburn is a name brand so it should be easy to find the replacement.
Feb 02, 2010 | Washburn D10sbc Acoustic Guitar
Need a wammy bar for a V-Tone Behringer Electric Guitar
whammy bars are available at musiciansfriend.com it looks like you have a strat copy they will need to know that
Oct 11, 2009 | Behringer Consumer Guitar Package
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Feb 26, 2009 | Washburn X10 Electric Guitar
I need to know how to adjust my truss bar on my washburn d10 to make the string action bigger
Actually you can do this by adding shims under the saddle to raise the action. Then use the truss rod to make the action uniform if necessary. I try to avoid making adjustments to the neck because it could lead to undesirable perminent alteration to the neck. If you do make adjustments to the truss rod you should tune the guitar to pitch and let it sit left alone overnight to allow the wood time to adjust to the new adjustments.
Here is a link to an article on Adjusting action on an Acoustic Guitar.
Jan 24, 2009 | Washburn D10sbc Acoustic Guitar
Music Logo
14 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
