Question about Konica Minolta bizhub Office Equipment & Supplies
Error code c1183
Hi....all of the sudden I received this code and my biz hub won't work! Help
  • Konica Minolta Master
  • 6,680 Answers
Model number would help
Posted on Jan 18, 2016
  • 6 Answers
SOURCE: bizhub 200 fault code c1183
Its an elevator ascent/descent motor failure. You didnt by any chance have any thing such as a big box of paper or a trash can sitting under the exit trays did you? Check it to make sure the trays are level also.
Posted on Aug 24, 2008
SOURCE: bizhub 250 c1183 fault code
Call Konica Minolta's Service Department 1-800-456-5664.
Posted on May 27, 2009
firecontrol7
  • 6680 Answers
SOURCE: biz hub 6500 has a code c3508 how do i clear it
If this code comes right back do not attemp to clear again, contact a certified service technician and have him or her look at this problem, it deals with fuser the hot part of the machine. Dangerious!!
To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen.
5.Press [01 Software SW setting] on the touchscreen.
6.Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
9. Exit Service mode to return to normal operation.
DipSW 3-1 is set to 0 without correcting the cause of the error, a fire may occur.
Posted on Aug 15, 2009
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Posted on Aug 23, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
In biz hub 500 the machine is showing error code c2803 what is this
My machine Bizhub 500 Sows a code 2803.Find its solution please help me.
Jul 12, 2012 | Konica Minolta Office Equipment & Supplies
Hi please can you help me to resolve my problem with a bizhub 35 it's get me a code number c1183
Hi elfethi,
This code c1183 is commonly caused by trays in your finisher which are not fully inserted into it's slot. It indicates an elevator motor Ascent/Descent Failure. You may want to try follow these steps that help you address the concern:
1. Check the output bin trays which are at the far left side of your machine.
2. Make sure that they are properly installed into the holders.
3. Then refresh your system by turning it off and on.
4.After doing these, the error should be gone.
If you're still getting the error after making sure that trays are properly installed then this means that the issue is already with the sensors or elevator motor. You will need to contact a local repair man.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Receiving error code:2,179,12 release the lock switch, detach the usb cable and reconnect.
I suddenly developed the same problem with my LiDE 210 Scanner. Plugging it into a different computer, and the scanner works. Plugged it directly into the original PC and it works. Plugged it back into my USB Hub and the same problem presents itself again. I found my AC powered USB Hub is no longer delivering the required current to the device. Replaced the USB Hub and everything is working fine again.
Jan 13, 2011 | Office Equipment & Supplies
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
Konica minolta biz hub C250 need to reset admin code URGENT
Oct 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
