Question about Kohler K-6356-7 Avatar Single Control Kitchen Sink Faucet, Black Black
Base of spigot leak
Took small screw out and cannot remove spigot. Pulled up hard but it's like spigot hits something solid. Spigot only moves up about 1/8 inch. Can't get spigot out to replace parts and not sure what parts I will need.
2 Suggested Answers
  • 25 Answers
SOURCE: The faucet leaks around the bottom when turning
Yes- a handle puller is required. My husband is a plumber. He says to go to a plumbing supply store to buy one. Also, u need to take off the brass clip with a screwdriver. It pries out. Good luck!
Posted on Jan 04, 2010
I have loose rubber tubes on my 1982 Suzuki GS 650 GL adn they are comming from the Carb on one side and have a screw on the other side any ideas
1. To correctly fix this the carbs will have to be removed from the rubber spigots completely and moved out of the way.
2. finish unscrewing the loosened screws and remove the rubber spigots and make sure to note which way they go so that they can be put back on the same way.
3. clean the back of the rubber spigots with laquer thinner or acetone and let dry for a few minutes. Also clean the head surface that the spigot attaches to.
4. apply a thin layer of gasket maker rtv or other suitable rtv to the back of the spigots and tighten them back down to the head.
5. wipe the extra rtv from inside and outside of the rubber spigot where it comes out of the mating surfaces.
Re-attache the carb and adjust the idle if needed.
If the rubber spigots are not sealed and tightened down, they can cause varying idle, popping throught the intake and exhaust pipe, hard starting, and bogging
Jul 19, 2012 | 1982 Suzuki GS 650 GT
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Price Pfister kitchen faucet with two porcelain controllers, one goose neck spigot and sprayer, chrome. Put the unit in about nine years ago. Starting leaking from base where spigot attaches to base with...
Should have o-rings remove those and lowe's,hardware,home improvement,plumbing supply stores should have what you need.Be sure to use plumbers grease or Vaseline on new o-ring and inside spout to keep from tearing new o-rings.
Jun 01, 2011 | Plumbing
The turntable does not move around when the microwave is on
ths is probably a failed motor they can go open circuit i have had a few where the fixing screws underneath that hold the motor fall out severing the drive spigot ,check if the spigot turns under the glass turntable if hard to turn will be motor failed cheap easy fix.
Mar 19, 2010 | Neff H5642 Convection / Microwave Oven
Delta faucet continues to leak I have replaced the upper seals around the ball but I don't know how to get to the lower seals in the neck of the faucet
2 little seals with springs use a small screwdriver or needlenose pliers to remove the seats and springs they come out easy just pull them out
Oct 27, 2009 | Delta 2402 Classic Single Handle Kitchen...
I am trying to wall mount my LG M197WDP - PZ 19'' TV but it has an ugly spigot that fixes to the free standing base. How can I remove this spigot? Thanks Dave
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Oct 22, 2009 | LG Televison & Video
Hooking carbage disposal to diswashing not sure where it hooks on the dishwasher itself
Waste line from dishwasher to waste connects to one of
  • small spigot on extension pipe above the disposal up high under counter
  • small spigot on side of disposal directly above sewer connection, below blade
  • small spigot on sewer line below disposal, but above U trap
at the dishwasher end, the hose connects to the pump output, under the base of the dishwasher, usually left side of center, there is no external spigot
you have to run the waste line under from the back, and connect from the front , by removing the kick plate under the door opening
Oct 30, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Feb 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Kohler K-6356-7 Avatar Single Control Kitchen Sink Faucet, Black Black Logo
37 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
