Question about Refrigerators
How does the white metal bar fit back into the crisper housing??????
Kenmore Coldspot model#106.74944401
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 19 Answers
SOURCE: Kenmore Coldspot is on but not cold after power blackout
The reset is called a klickson it is inside that black cover on the side of the compressor.
sometimes they do fail.
Posted on Dec 28, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Posted on Feb 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: Just moved Kenmore s/s co;d spot. edges are now hot
This is caused by a failed condenser fan motor. Since it was recently moved, I suspect the fan blade has been blocked from spinning. Pull the fridge out and remove the cardboard cover near the floor. See the fan? Check for obstructions. If there are none and the fan is not spinning, reach in there and give it a whirl with your finger. It may spin right up, it may not.
If all else fails, you'll need to replace the fan motor. Write back with the model number and I'll get you part numbers and step you through the repair. Deal?
SG
Posted on Mar 29, 2009
  • 1891 Answers
SOURCE: My icemaker is turned on and hooked up properly
your mod is probably type with wlect eye , if ice bucket is on door . this is the type you have , and no lever is on icemaker . the problem is with the eye .. replace the eye kit . this is a very common problem . new kit is revised / and works good .. mm feed back pls .
Posted on Dec 17, 2009
Testimonial: "Sweet man, thats it....Love you brother..."
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
Kenmore coldspot 106 door handle is loose
Gently slide the handle up until it releases. Then slightly turn the screw underneath it, and slide the handle back on. Do this until it fits properly.
Jul 28, 2013 | Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
Cleaning refrigerator & have a bar I don't know where it goes Whirlpool Model - ET1CHMXKQ02
If the bar is long , it probably fits inside the crisper cover which has a U shaped slot for the bar to slide into .
Aug 25, 2009 | Whirlpool Refrigerators
SG
Mar 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Part number 6
Feb 27, 2009 | Kenmore Refrigerators
Kenmore Coldspot Ice Maker Gear Broken
best bet os to order and replace the entire assy, the gear broke due to an over torquing problem that they fix with a kit that ioncludes a new module and a new stripper bar, the labor involved and chance of breakin more parts make the entire assy a more feasable way to go, you can proble find a repacemnt online for undder $75
Feb 12, 2009 | Whirlpool ED2FHEXN Side by Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
