Question about Refrigerators
The action of an ocean wave is perpendicular to the direction of the energy flow
What is a tsunmi
Humongous tidal wave
Aug 22, 2017 | Miscellaneous
What are the effects of a 7 mile meteorite crashing into the North Pacific Ocean (such as the one predicted by Nostradamus)? Would the tidal wave reach Denver, Colorado? Or just the eastern seaboard?
If it fell in the North Pacific it wouldn't have direct effect on the Eastern seaboard would it, that's the Western seaboard. East is the Atlantic. If you live close by it won't matter anyway?
Nov 03, 2014 | Audio Players & Recorders
When do tsunamis happen
Tsunamis happen when there is an underwater earthquake, causing the ocean floor to move violently up or down. When the ocean floor moves like that, the water above it has to go somewhere so it spreads out in a very fast wave. The wave is a tsunamis.
May 27, 2014 | Computers & Internet
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Summarize how the overharvesting of a single species,a baleen whale, can affect an entire ecosystem
Different whales frequent different areas, and when they die they bring alot of energy to the bottom of the ocean where light cannot penetrate and therefore plants cannot live. A whale carcass can last for a decade and provide a meal to thousands of different creatures, like the one mentioned in the video who is specialised in eating whale bones. If no whales die, and fall to the bottom of the ocean, these creatures starve, and so, in turn, do the creatures that prey on them.
Baleen whales eat mostly krill. Krill eats algae, which is essentially turning sunlight into food.
So therefore whales are moving energy from the top of the ocean to be bottom.
Also sharks and orca prey on on a baleen whales calves, and there are fish they live in a symbiotic relationship with the sharks, like the ones that eat barnacles and parasites off the skin and gills of the whale.
utube.png You-Tube video "rdI3eFrTGs8" placeholder
Mar 09, 2011 | Toys
The white rectangle on the top of the inside of the microwave has a hole burned in it. What does that mean?
The waves won't be spread like they should, with the area right below the hole getting way more energy than the rest of the food. The new part will be around $22. I had to break the old part in getting it off. The new part will show you how it is attached and how to install it. The most substantial part goes in the back (the part that acts like a hinge), and the snap-in area goes in the front. It pops right in and the energy once again flows all over the microwave. I got the idea that the cover acted as a diffuser. Also, I was told the reason this happened is because whatever was being heated didn't have enough moisture in it, therefore it was as if the microwave were being run with nothing in it, and the wave were directed back to the cover instead of being absorbed. I was instructed to next time put a cup of water in with whatever I was heating at the time of the problem.
Feb 13, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How well does the Fish Hunter 280 do in the Ocean?
I don't think it would do well at all, Ive taken my Fishhunter 360 in larger lakes with waves and came close to tipping quite a few times with all the gear, motor,etc. Try an inflatable with a v-hull if the oceans your thing!
Oct 15, 2010 | Stearns SEVYLOR FISH HUNTER HF280 9' 2"...
Causes of Tsunami
Tsunami is a Japanese word meaning ''huge wave'' that refers to a series of large ocean waves. It is caused basically due to underwater earthquake, Richter magnitude exceeding 7.5 to produce a destructive tsunami.
Concept can be summarized as follow:
The earth is constantly moving on large tectonic plates. When these tectonic plates moves past each other, collide and/or slide under one another an earthquake results. This is what happened with the recent tsunami that devastated Southern Asia. A massive earthquake in the Indian Ocean measuring 10.0 on the Richter scale jolted the seabed causing the sudden displacement of a very large volume of water. The earthquake temporarily produces a fluctuation in the mean sea level of a specified area. Waves quickly form as the displaced water tries to recapture equilibrium by filling the vacuum that was created. Tsunamis are a series of extremely long waves that are created after a large volume of water is displaced. The amount displaced must be significant enough to create waves underwater in the vast ocean. Waves are formed as the displaced water mass moves under the influence of gravity to regain its equilibrium. The larger the displacement, the larger the wave generated.
May 03, 2010 | Yosemite Technologies TapeWare 7.0...
Science
the light is fractured to a certain extent that when freyed it will split apart but i am a 13yr old so i probably have virtually the same knowledge of this subject that you do.
Good
Dec 10, 2008 | Vector Power On Board High Intensity...
My Helio Ocean has a nonresponsive keypad.
solution: throw the piece of s**t in the trash
Aug 21, 2007 | Helio Ocean Cellular Phone
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
