Question about Neff Microwave Ovens
Neff microwave touchpad not working
It will work on occasions ,but its intermitent
5 Suggested Answers
SOURCE: Neff Microwave
check control circuit and full wiring and connectors.
Posted on Dec 01, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
  • 6771 Answers
SOURCE: The touchpad on my Westinghouse Microwave stop working
You must replace the whole keypad control board in order to get everything back on track.
Posted on Apr 21, 2012
My Sanyo edm9550 microwave won't allow me to set the clock. After being plugged in and pressing the 'clear/stop button, all buttons become inactive. In the past, we have had the odd occasion when nothing...
see the chart troublshooting and fix it.
God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2gUPTDli3
Oct 01, 2013 | Microwave Ovens
Ge spacemaker microwave repair manual
see the diagram and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jul 08, 2013 | Microwave Ovens
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Touch pad on my whirlpool wall oven works intermitently..I usually get it to work but it is fussy. Anythng I can do to get it to work better??
no,, usually that touch pad must be replaced this is a commom problem with those touchpads,, u might have a bad ribbon connection but will only find out once u get acess behind that panel may require pulling unit out,, some had 5 year part warrantys so u may wanna check your owners manaul for specific warranty options..
Feb 06, 2010 | Whirlpool MH1160XS Convection/Microwave...
NEFF 7871 electrical problems
neff built in microwave cannot open the door
Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
Neff Microwave
Dec 01, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
