My 2 year old technika tv will intermittently not switch on, just ends up as a blue screen. After pressing various channel buttons get ' Channel not available' or sometimes a message about checking t
HDMI 1, PLUS STEREO SHOW UP IN RIGHT HAND CORNER OF SCREEN, THEN EVERYTHING DISAPPEARS INTO THE BLUE SCREEN, AND NOTHING ELSE SHOWS. tv CONTINUES TO PLAY DVD'S OKAY. REALLY FRUSTRATING. Suggestions welcomed
techman
  • 3130 Answers
SOURCE: cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Posted on Aug 18, 2006
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
Krenn
  • 59 Answers
SOURCE: signal periodically disappears
do you know if reciever WL-167G is using any type of password or wireless security protocol?
Is it possible that the router is set to only allow certain mac addresses to connect?
can you log into the router to check its records and wireless settings?
Posted on Mar 29, 2008
thatroom
  • 31 Answers
SOURCE: No music out of stereo when using Mororola DC800 and Sony Vaio FW
It's a lot simpler than you think..
1. make sure the cables to your stereo are in the LINE OUT of the dc800, and on the LINE IN or AUX IN of your stereo (trust me, double check them)
2. make sure your DC800 is PAIRED with your computer. this is different with each different "STACK" read the help files on your particular bluetooth stack to help you with this is you need more help. Remember, you have to hold the big "M" button in the front of the DC800 to pair it.
3. when you want to send audio to the DC800, make sure you CONNECT the DC800 using your particular stack. Once the DC800 is paired with your computer, you can often set up a link or icon on your desktop to connect or disconnect the device from your computer.
This should take care of it. If you are still having problems, make sure to check your audio properties to see if the audio is sending to the Bluetooth device. This is USUALLY changed automatically, but sometimes you have to tweak your settings to make sure it's sending to the Bluetooth.
Posted on Dec 20, 2008
SOURCE: Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Posted on Jan 10, 2009
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
I have a Gold Star TV, several years old, that is stuck on a black screen with AV on it. I pushed the wrong numbers to change the channel and cannot get it to f\go back to tv mode. Can you help me?
If you have the remote, press the AV/TV button. If you have no button with AV/TV written next to it, look for a symbol that is the outline of a TV with a small + sign in the corner. Or, worse case simply press each button one by one, until you find the one that switches the channel. If you bring up something on screen you're not sure about, turn the TV off and back on again.
Jun 09, 2011 | Televison & Video
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
How can I place tv on channel 3 with out remote?
Near the switch ON/OFF button there must others that control the volume and the channels. Usually the channel switching buttons have an arrow pointing Up and another pointing down. The two button may be the up end and down end of a bigger button. That is the general idea. But you should examine the TV around the control buttons looking foe some inscriptions that will help you identify which is which.
Turn your TV on. Identify the volume control buttons.
By pressing on the button (or the button end) with an UpArrow you ascend the channels. Pressing the button with the down arrow decreases the channel number.
Jan 30, 2010 | Emerson Televison & Video
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Channel number does not go away
Press Display / Info button on "TV's Original Remote", on-screen display of channel number will disappear.
Dec 06, 2008 | Televison & Video
Technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Nov 10, 2008 | RCA Universal Remote Control
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
