Question about Stihl MS171 12" Chainsaw
Replace trigger wire on stilth ms 171 chainsaw
  • Stihl Master
  • 1,807 Answers
MS 171. What is the compression supposed to be?
I cannot give you a number but I can tell you how I check to see if there is enough compression. I remove the spark plug and place the plug and wire away from the plug hole so you don't get a shock. Then I put my thumb over the hole firmly and pull the start cord. You have enough compression if you can not hold the air from coming out of the cylinder.
Jun 26, 2015 | Garden
My saw dies out when I press on the trigger then it picks up after a second or two. What can I look for?
check the air filter and replace fuel filter there cheap should fix it bc its not getting enough of either one
Jul 28, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I was replacing the throttle trigger on my ms 180 c Stihl but the throttle rod was disconnected from the throttle. I can't find the throttle to connet the throttle rod. and there is nothing i can find on...
The rod connects to the right side of the carburetor. There is a hole that you rotate the curved end of the rod into, then install the other end of the rod into the trigger.
Aug 14, 2013 | Stihl Garden
How do I reconnect ,my throttle trigger for ms 260
remove the top cover on the handle, there is a screw in the bottom of the handle end. put the on off switch in the choke position all the way down, connect rod to throttle on carburetor then slip it into the hole in the trigger. replace operator presence lever making sure the spring is in the notch on the side of it, while holding it in place reinstall the top cover.
Jun 13, 2012 | Stihl 024 026 Ms240 Ms260 Throttle Trigger
When motor is running I have no chain drive when trigger is pressed.
check and see if clutch is working or chain is adjusted too tight.
Dec 02, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Start proceedure for ms171 only have french instructions
Stihl MS 171 OM follows.
http://www.stihlusa.com/stihl_ownersmanuals/MS171_181_211_Manual.pdf
Starting procedure starts on page 6.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 22, 2010 | Garden
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl MS171 12" Chainsaw Logo
152 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
