Question about HP Office Jet 4500 G510n
Rail banging The cartridge is moving from left to right on the rail and bangs the side
  • 27 Answers
SOURCE: printer ink cartridges move along the bar and then stop
All the HP 500 and 600 series are noisy like this. To help the problem, you would need to open the unit and blow out any dust and paper particles with low pressure compressed air. Put on some latex (medical type) gloves and wipe down and clean all surfaces with a paper towel soaked in 90% isopropyl alcohol (it will be messy). You will have to use multiple paper towels. Check all rollers and insure they will roll. Check the carriage and drive belt for damage. I would also spray a Q tip with WD-40 and swab a light coat on the carriage bar and at the metal edge of rollers (where there are bearings). If this doesn't resolve the banging noise, then there may be a problem with the stepper motor or gearing (plastic gears). This is not normally user serviceable and is not cost effective to repair. You buy a new printer.
Posted on Jan 29, 2007
SOURCE: 970 Cse cartridges bang over to the left and then nothing
I had the same problem with my HP Deskjet 970Cse which was quickly resolved by going to the below HP site and looking under the Issue: The carriage is stuck or makes a grinding noise. Note that the blinking lights displayed as: Resume Light Blinking Simultaneously AND Power Light Blinking Simultaneously.
The Solution:
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer.
5. Take out the cartridges and close the top cover.
6. Plug the power cord to the back of the printer. Turn the printer on.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Hope this helps as it worked for me.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&cc=us&lang=en&product=60097&dlc=en
Posted on Jun 30, 2008
tunmun
  • 413 Answers
SOURCE: hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Posted on Jun 15, 2009
  • 26 Answers
SOURCE: Hi, my deskjet 3845 when turned on the carrier
Try the steps given in the below document and check if it resolves the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00037764&tmp_track_link=ot_recdoc/c01082964/en_us/c00037764/loc:1&lc=en&dlc=en&cc=us&product=372330
Posted on Jul 18, 2009
  • 19 Answers
SOURCE: HP Deskjet F380 does not print. On screen message:
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
I have a DELL 968 printer. Initially I was getting an error message "printer carrier stall". I was told to clean the encoder strip by using a lint free cloth. I have done this, but there is still...
1).check the conectivity for carrage cable if you found a any point is brocken then you should have to change the carrage assembly(cartage cardel),.
2).if after clining of encoder stripe its stucking to right or left side then change the encoder stripe.
3).check the logic card connection and if needed make dry soldring.
May 16, 2011 | Dell 968 All-In-One Printer
Power seat won't move backwards
I had the same problem some one on one of the web-sites solved his problem by banging on the track rail in the front while pushing the seat button back after a good few bangs it unjamed and works great now .I feel like I saved at least $1500 by dealer rates.
Jun 15, 2010 | 2003 Toyota Camry
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Epson Stylus Photo RX600: Banging noise when turning on printer
Ok I think this is the cartridge carrier doing the banging I have had this on 2 or 3 epsons that I oncwe owned. If you clean those rails that the cartridge container slides on the banging should cease. Dont need to oil them just a damp cloth will do it. You can try sewing machine oil later. only a very small drop ( smidgen) on a cloth to wipe both rails.
Please rate our help and keep this site alive
Aug 16, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Canon Pixma iP 6210D: cannot replace cartridges
the drive control is malfunctioning and costs more to repair than replace
Jul 07, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Dell printer 944 shows carrier jam and when you press the arrow button as shown on the screen but the cartridges move to the left and right banging both the sides and then stops on the sides.hope anybody...
Try this procedure:
1.Disconnect the power supply from the back of the printer.
2.Open the front cover of the printer where the cartridges are located.
3.Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
4.Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
5.Close the front cover of the printer and reconnect the power supply.
6.If the problem persists, you may need to contact Dell Technical Support.
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark z23 cartridge banging
The encoder strip may have become unseated. please follow the steps given below:
The embedded links in the table lead to specific troubleshooting steps.
1 Turn off the printer and disconnect the power cable from the back of the unit.
2 Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back.
4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5 Reconnect the power supply and turn the printer back on
If the issue persists after you have attempted the steps with a new color cartridge, continue to Contacting Lexmark.
Jan 31, 2009 | Lexmark Z2300 InkJet Printer
System error 000 carrier stall Presss power Key
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
HP Office Jet 4500 G510n Logo
Seeker5211
Seeker5211
