Question about Casio QV-R51 Digital Camera
Zoom broken hi my camera is not switching on, also the zoom is not coming out. when i press "on" button, it just makes a little sound and just switches off.i used this camera not for so long, and now this happened.please help, thank you.
  • 23 Answers
I think the zoom is stuck inside the camera. You need to send the camera to service or repair center.
If you are from India, I can surely help you as I am the Repair Engineer at Jaipur, Rajasthan India.
My Contact Nos. are +91-9214988557
Warm Regard's
Manoj Goyal
Posted on Mar 06, 2008
  • Manoj Goyal
    Manoj Goyal Aug 11, 2009
    Sorry for the very much delay.
    Yes, the problem is with the zoom.
Camera lens in jammed?
Take it in for a checkup.
Something broken or loose.
Only experienced camera techs can fix.
Nov 23, 2017 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Problem with zoom and touchscreen
there is two problum in your camera one is lcd defective & other is lsv assy so please go to youe nearst sony service centre & fix these two problums
Apr 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
It zooms all the way to the maximum on its own;
That sounds like the zoom button is either jammed or broken. Try pressing on the zoom buttons and see if you can release it from zooming constantly.
Also, you could take out the batteries / battery for 5 minutes and then try again, if it keeps doing it, the button is either jammed or broke and it might need to be replaced.
That is the most likely problem.
Dec 17, 2009 | Cameras
When I push the button to take a photo, the camera
Sounds like a broken gear or linking arm. It will cost as much to fix as to replace. You now have a very nice Minolta paperweight, lol.
Those neat little film cameras are now a thing of the Ebay, LOL. Since many are dumping them for digital, they're quite available at good prices now.
Nov 14, 2009 | Minolta Freedom Zoom Explorer EX 35mm...
you just try this ,first cut plastic picise size of the pins ,may be there is west calculator's plastic is best for it, and fix it properly by using plastic solution ,like FAVI QUICK just try this carefully,
hope you are understand ,
Aug 31, 2009 | Olympus Camedia C-5060 Wide Zoom Digital...
The zoom won't work on my Canon A460
Your zoom may be turned off, here is how you can turn it back on:
When you are about to take a picture, press the little menu button, then press down until it says digital zoom, if the little black box is over-top of 'off' change it to say 'on'.
Hope this helps.....and makes sense.
Dec 30, 2008 | Canon PowerShot A460 Digital Camera
Half of the buttons don't work
Hi, my M417 acted the same way. Would only power on and then any button would only make a little "tick" sound. I also tried taking the case off and my camera worked as well. What I spotted was that the switches are little metal domes which pop down in the center when the plastic button is pressed to make a connection between metal traces on the circuit board. The little domes are not attached to the board but are only held in place and located by some thick clear tape over the board. A couple of my switch domes had "drifted" out of position and so when in the case they had enough pressure for their edges to be making contact at all times so they were always on. I lifted the tape with a small knife blade and slid the domes back to where they belonged and now the camera is back to normal!
Apr 20, 2008 | HP Photosmart M417 Digital Camera
Make sure you are pressing the button half way and getting the 'beep' that the camera is ready to take the picture before pressing the button all the way down.
Also make sure you have good lighting conditions and use the flash if needed.
Last, make sure you are still in optical zoom and not digital... I would suggest turning off digital zoom, I don't recommend using it at all.
Hopefully this helps..
Apr 13, 2008 | Canon PowerShot SD850 IS Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom button broken
If you can pull the camera apart (carefully) and find the zoom switch it could be that the switch itsekf has jumped the actuator. I don't know what method your camera usues but most use a rocker type switch. On the underside of this switch would be a slot which when pushed one way pushes against a small lever of piece of plastic. Let it go and the switch centres itself taking the lever with it. Push the switch the other way and it moves the lever or plastic in the opposite direction. What sometime happens is the lever or plastic somehow gets on the wrong side of this slot. So it will only push the lever in one direction. What you'd have to do is remove the top of the switch and center the lever or piece of plastic and put the camera back together. If your zoom is 2 seperate switches then one of the swiches is either faulty, the pin on the underside of the swich is broken or there is a foreign object stopping the switch from activating. You should be able to tell which one it is simply by the feel of the switch. if it's loose and wobbles around the pin would be broken. If it feels stck then maybe there's something stopping it. If it does neither of these things it could be just a faulty button switch which means you're up for a complete switch cable assembly. Good luck putting it back together. Just be patient and don't force anything. BMW
Jun 07, 2006 | Fuji FinePix A340 Digital Camera
Casio QV-R51 Digital Camera Logo
83 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
