Question about Husqvarna 225h60 / H75 Hedge Trimmer Owner Manual
How to replace primer ball - Husqvarna 225h60 / H75 Hedge Trimmer Owner Manual
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
Eager 1 manual
a screw driver fate tip and sharp you have to pry out the retainer clip once out pull out primer ball put new primer ball in put a new retainer ring on find a socket big enough to be put over primer ball and will sit on retainer ring push the ring in till seated
Aug 15, 2014 | Garden
What else should i try
Make sure lines are connected correctly. On the back of primer it is stamped In & out
Jul 25, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Sounds like the check valve in the primer base is stuck/clogged/damaged, assuming the fuel lines and fuel filter are intact and not clogged, It will have to be replaced.
Jul 25, 2014 | McCulloch 2816 Edge Trimmer 28cc
Craftsman 32 cc
theoretically the primer ball is the t connector.
Aug 01, 2009 | Craftsman 25cc Gas Line Trimmer
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Husqvarna 225h60 / H75 Hedge Trimmer Owner Manual Logo
35 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
