Question about Dell OptiPlex GX520 PC Desktop
Drive 0 not found serieal ata ,sata-0 - Dell OptiPlex GX520 PC Desktop
melnavz
  • 1226 Answers
SOURCE: Dimension 3100 Won't Boot
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
Posted on Jan 16, 2008
mansnes
  • 50 Answers
SOURCE: drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Posted on Feb 06, 2008
  • 58 Answers
SOURCE: Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Posted on Mar 15, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Hi My hard drive crashed can it is old can it be
Most likely scenario is the drive is dead, but also the BIOS on your computer is old itself, I believe there are a few BIOS upgrades available for that model, might want to check with Dell support site. If you have access to another computer, there is a way to check your drive. Go to a computer retail store or on Ebay, but a EIDE/SATA to USB adapter. This will allow you to take a hard drive out of the case and attach this adpter to it and plug the usb side into another computer, laptop, doesn't matter...that computer will read the drive as an external hard drive....if the drive is indeed still viable. If it is, this would be a good time to save your files to the other computer for safe keeping until you can get your other system back on its feet.
Posted on Oct 10, 2009
Testimonial: "Very FAST and good advise, Thanks"
  • 11800 Answers
SOURCE: Drive 0 not found :Serial ATA, SATA-0
The hard disk has died, junk it and install a new one.
Posted on May 08, 2011
May 08, 2011 | Dell Dimension 8400 PC Desktop
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
Drive 0 not found Serial ATA, Sata 0
Check the jumper settings on the primary hard disk drive and set to master. Also check that the cables and connectors are firmly in place.if problem persist, drive may be bad
Sep 17, 2009 | Computers & Internet
When my computer was started in monitor display MBUltra133 (tm) BIOS Version 2.20.0.1. MBUltra133 BIOS is not installed because there are no drives attached. SiI 3112 Serial ATA Host Controller BIOS...
If you are looking at Device Manager, the computer must be working to some degree. Since there are no drives on the SATA controller, you're probably using an IDE drive and don't need the SATA controller anyway. Disable it in the BIOS. And get more memory.
Dec 11, 2008 | Computers & Internet
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
Drive 0 not found;serial ATA,SATA-0
Feb 06, 2008 | Dell Dimension 3100 PC Desktop
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
71 people viewed this question
Alun Cox
