Denon dra f101
Function button not working
  • 119 Answers
SOURCE: denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Posted on Mar 02, 2009
SOURCE: I HAVE A DENON DRA-397
Make sure you are using the main power button not the standby button and you should be fine
Posted on Jun 27, 2009
SOURCE: looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
Posted on Sep 21, 2009
  • 137 Answers
SOURCE: Denon DRA-397 - the stand by button light is
You may want to check your output transistors,They are the ones mounted to the big heat sink.With a ohm meter measure across one of the legs to another there should be no shorts.If you see anything burnt that channel will be bad causing the unit to stay in protect mode to prevent futher damages
Posted on Apr 22, 2010
kapishtech
  • 2272 Answers
SOURCE: I need to connect denon
The set up with other wireless network can be done this way.set-up is as follows: a BT Total Broadband Home hub wireless router in combination with a D-Link DWL-G810 54Mbps Wireless Ethernet Bridge attached to CHR-F103 system via its Ethernet port at the rear. The USB port by the way, also at the rear, is not meant for this function, it is for connecting to your PC for use with the Denon Music Manager software which should have come with the unit.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 04, 2010
How do I remove "panel lock on" function ?
There is a firmware update that is supposed to help with this problem, but it's not something that the consumer can do. You would have to take it in to a shop for this to be done. You might want to try and contact Denon customer service and see if they will do anything for you.
Aug 12, 2014 | Denon DRA-397
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
Denon DRA-397 - the stand by button light is blinking red and I have tried the reset but it did not work. Does anyone have any other ideas?
Feb 18, 2010 | Denon DRA-397
I have a Denon DRA-397 Receiver. It was stuck with the "Panel Lock" but I followed the instructions here to hold the "B" and "Mode" buttons while powering on. It unlocked the panel. Now the Reciever is...
Check for a reset of the receiver. If no mention in manual you might want to check with the manufacturer for a code . If nada then the electronics are fubar and you are SOL.
Aug 31, 2017 | Denon DRA-397
Denon DRA397 Panel lock on.
Denon has for some reason removed this function from their user manuals. However The manual does show how to do a manual reset of the unit. This may correct the issue.
With the Amp OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another second or so. The display should all light up and flash at 1-second intervals. If not flashing, try again.
This should reset the unit back to factory state with the front panel lock disabled.
Jul 07, 2009 | Denon DRA-397
Looking for Denon dra 1025r Service &/or user manual
May 06, 2009 | Audio Players & Recorders
Denon receiver (DRA 397) will not speak to iPod dock
Oct 13, 2008 | Denon DRA-397
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
13 people viewed this question
 Grubhead
Grubhead
