Question about Keurig B31/K10 Mini-Plus Personal Coffee Maker - White
K10 mini plus makes humming noise when not in use
Makes humming noise when not in use
My K10 mini keeps shutting itself off
It is normal for a Keurig mini to shut itself off after 90 seconds of inactivity. Reference page 17 of the manual.
https://www.greenmountaincoffee.com/~/media/B2C/Files/Keurig%20Brewer%20Manuals/B31MiniPlus_manual.ashx
Feb 19, 2014 | Keurig K10 Mini Plus Single-Cup Coffee...
My K10 MINI Plus keeps shutting off by itself
The shut down may come from a safety standpoint, whereby if a heater gets too hot, lines get plugged, or chambers are not filled with water as necessary; the unit could shut down accordingly. Try to clean the ports/lines/ and cup holder. Fill water to line (Not Over the line) and descale to clean the interior chamber.
Feb 19, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
How do I get a manual for a Keurig K10 mini?
You go to the Keurig website:
http://www.keurigtroubleshooting.com/keurig_user_manuals.html
Jan 03, 2014 | Keurig K10 Mini Plus Single-Cup Coffee...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
When I use the egg whisk attachment on my 'Le Mini Plus' model Magimix it vibrates and makes an awful lot of noise and it takes much longer than it used to whisk the eggs sufficiently. Any suggestions...
the attachment is likely bent out of shape making it off balance.I would suggest a new one ,if you dont know were to get one already try-searspartsdirect.com
Oct 11, 2010 | Magimix Le Mini Plus 719 Cups Food...
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Keurig B31/K10 Mini-Plus Personal Coffee Maker - White Logo
94 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
