Reset life for Xerox 7800 belt cleaner - Office Equipment & Supplies
SOURCE: xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Posted on Dec 09, 2008
  • 2072 Answers
SOURCE: our xerox m24 workcentre needs a new belt cleaner
Yeah, you do. Sadly that is only on a Xerox rep laptop.
The diagnostics in that machine are not in the processor but accessed via laptop.
Instead of calling Xerox, you can look up a dealer in your area. They would do it and if you have no maintenance agreement they will do it for much much cheaper, what city to you live in? Let me know and I will send you the names of dealers in your area.
E-mail me at rak458@aol.com dont want you putting your city name on here. I will look them up and send you the info on dealer service in your area.
Posted on Feb 12, 2009
  • 2072 Answers
SOURCE: NEED TO CHANGE THE TRANSFER BELT & CLEANER XEROX M24
Total Document Solutions 2515 N. Shiloh Drive Fayetteville AR Y (479) 575-0770
Posted on Feb 20, 2009
  • 2072 Answers
SOURCE: change belt cleaner?
You have to move or remove the finisher, depending what finisher you have.
Open the door on the right side of the machine . It is about 4 inches high and 14 inches wide.
Open the front cover and move the black bar to the down position as if you were replacing a drum.
Then on the right side, you slide the transfer unit out about 4 or so inches. On the front of that unit there are 2 torx screws held together with a black plastic strip. Remove those 2 screws, remove and replace the cleaner.
Posted on Dec 31, 2009
StevenC82
  • 160 Answers
SOURCE: We just replaced the Belt
Yes, you have to reset this. From the main menu scroll to "Supplies Info" and hit OK. Now scroll down to "Reset belt cleaner Assembly Life" and press OK. Good luck, and thanks for using Fixya!
Posted on Sep 05, 2011
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
I just replaced the Belt Cleaner Assembly in our Xerox Phaser 7800 as it was stating it was at 0% and PAST end of life. Now I have installed a new one, the same message is still up! Help!
It may be another part that is past end of life, The imaging unit may also need replaced, once a new part is installed the printer should pick-up on the new part (Except belts) and reset itself. Often this line of printer fails to reset after a new part is installed. Xerox offers little to now support on this error, except sending in for repairs. However many people have said turning the unit off, unplugging it, sometimes fixes this issue.
Others have stated the problem "Fixes itself" after a while.
In my experience, removing the cartridges or imaging units and reseating them can sometimes cause the device to reset but not always.
Nov 21, 2014 | Xerox Office Equipment & Supplies
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
We just replaced the Belt Cleaner Assembly on our Xerox Phaser 7750 printer and still get the message 'replace belt cleaner assembly. Do we have to push a reset button or something? Phil Biebl,...
Sep 01, 2011 | Xerox Phaser 7750GX Laser Printer
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
Aug 02, 2010 | Xerox WorkCentre M-24 Color Copier
Our xerox m24 workcentre needs a new belt cleaner
Feb 12, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox printer error
  3. Press OK.
  6. .
  7. Press OK.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
999 people viewed this question
jasbo
jasbo
