Question about D-Link DSC-350 Digital Camera
Shutter will not open - D-Link DSC-350 Digital Camera
The copier is saying: Turn the main power switch (on the main unit's right side) OFF & ON again. If the machine still does not operate normally, contact your service representative with the error...
The shutter open sensor does not go on. (The shutter does not open.)
1. Check the shutter home position sensor. Is it normal? 2. Check the wiring between the finisher controller PCB and the stack feeding motor and between the finisher controller PCB and the shutter open/close clutch. Is it normal? 3. Is there a fault in the shutter mechanism? 4. Try replacing the stack edging motor and the shutter open/close clutch.
May 11, 2011 | Canon imageRUNNER 5000 Copier
Is it possible to achieve a 20sec shutter release via remote control
With or without the remote control, in the M exposure mode you can select the bulb/time setting. Without the remote, this opens the shutter when you press the shutter release and holds it open while you keep the shutter release pressed. With the remote, this opens the shutter when you press the button on the remote and keeps it open until you press the button again. This allows you to keep the shutter open for up to 10 minutes.
Nov 29, 2010 | Nikon Coolpix 8800 Digital Camera
The pictures are coming out black.
Sounds like the film is not exposed, shutter not opening. If possible fire the shutter with the camera open/back off, pointed towards a light source, if the shutter opens you will see the light thru the shutter/lens. If no light is seen then the shutter is stuck.
Oct 28, 2010 | Polaroid MiniPortrait 203 Instant Camera
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
When i take it to develop film cames back the shutter not closing or opening ? on pic onit at all
I would check the shutter by:
1) open the film door
2) While looking into the camera, press the shutter button.
The shutter should open and then close. If the shutter doesn't open and then close, it could be stuck and my require professional help.
Jul 01, 2010 | Nikon N75 with 28-80 lens 35mm Film Camera
Its shutter is not opening
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 18, 2009 | Canon Cameras
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
D-Link DSC-350 Digital Camera Logo
13 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
