Question about Yamaha RXV671
Rx 671 standby problem - Yamaha RXV671
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
How to power up av receiver
Connect the AC power chord provided with the Receiver and switch-on power - the standby indicator glows now press the standby switch to power on your receiver
Jun 20, 2015 | Yamaha RX-A1020
I want to hook two speakers (4ohm each) on rxv-671 on both L/R side. what is the best option to do that either parallel or serial? Also plz describe the method if any.
The best method is - DON'T. When you hook more than one speaker up to a single speaker output, it drops the impedance that the receiver sees and you risk blowing the amp. If you need to hook more than one up, do so through a speaker switch box. It will match the impedance correctly so the amp doesn't get damaged.
Sep 22, 2013 | Yamaha RX-V671
Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Oct 30, 2010 | Midland LXT365VP3 Two Way Radio
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Yamaha RXV671 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
