Question about Philips 47PFL3603D LCD TV
PHILIPS 47PFL7404H/12 tv not responding to remote
2 Suggested Answers
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
Philips TV not responding to remote
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. Ome among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
If remote control is found OK, check and replace the infrared sensor inside the TV.
Mar 19, 2014 | Philips Televison & Video
I have a Philips CL043 universal remote. I can't find th tv code for a Westinghouse lcd tv.. can you help?
You can find codes for the remote here: http://www.urc.philips.com/ . Then look up the CL043 and click on the remote code finder. This is also called the SRU3004WM by Philips.
A Westinghouse TV should responds to one of the following codes: 0915, 0013, 1216, 0300 if the TV was released 6 months before the remote was programmed or earlier. (Whte Westinghouse codes are different.)
If those codes do not work, there is a manual code search option. With the TV on, press and hold Setup on the remote until the red indicator stays lit. Then press and release quickly the TV button on the remote (the LED will blink once). Then press the Channel Up button until the TV responds (up to 300 times). If you overshoot, press Channel Down to go back to the previous code. Press and release the Mute button to set the code. Check if the remote performs all the needed functions. If it doesn't, repeat the above steps to find another code.
I hope this helps.
(if the remote is older than the TV, you may need a newer universal remote.)
Jan 08, 2011 | Philips 5-Device Universal Learning Remote...
MY PHILIPS 42" LCD SUDDENLY STOPPED RESPONDING TO OEM REMOTE AND DISH REMOTE. BOTH REMOTES ARE GOOD
The TV processor is locked up, unplug from wall for 40Min, and it will reset back to normal.
Oct 18, 2010 | Philips 42PFL3603D 42 in. LCD TV
My philips 42 lcd will not respond to the oem remote or dish network remote. Both remotes are good
Click here at Philips firmware support center seems like this could be a firmware problem as Philips is known for in the TV repair trade. Download the latest version upload too your TV via connect card or USB see if this clears this problem. If not then its probably the infra-red sensor in the TV which is not working and needs to be replaced. Also be sure there are no parental locks which could influence remote control response...
http://tvtechwork.webs.com/
Oct 18, 2010 | Philips Televison & Video
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Sanyo and tv remote problems
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips
If you know the model of your Phillips remote, you should be able to fihd it here, download the file, then unzip user guide. Hope this helps.
Aug 18, 2009 | Philips Magnavox Learning Universal Remote
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
DVDrecorder not responding
try a power on reboot. hold the power button for 12 seconds until it reads "recover"
Rolling picture could be a loose cable or TV on the wrong channel.
Jan 06, 2008 | Philips DVDR3320 DVD Recorder/VCR
Sep 19, 2006 | Philips 28PW6506 28" TV
Philips 47PFL3603D LCD TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
