Question about Drills
Dewalt 9118 charger not charging
Fast red flashing led .35 volts output
SOURCE: battery charger
Take your charger out on a boat and dump it into the sea. Then go to the store and buy a new one.
Posted on Aug 17, 2008
frankzen
  • 19 Answers
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Posted on Apr 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: when put on charge the green and red light flash
that usually indicates a bad battery. I would unplug the charger for a couple minutes to reset it and then try again before looking at replacing the battery. Most shops have a tester there that can tell if it is in fact bad.
Posted on Jan 23, 2010
emissionwiz
  • 76164 Answers
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
Posted on May 18, 2011
  • 885 Answers
SOURCE: broken dewalt battery 18v lithium ion
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Posted on Jan 30, 2012
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The charger flash red very fast with battery charging and the battery will not recharge
This means there is a "pack condition" and the charger believes the battery is bad.
Nov 24, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
May 18, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
No charge
If it's not charging most likely it hasa bad battery to see go to the store where you boughtthe dewalt and have them try putting it on a charger and see if it will take a charge, also the tongs inside the charger could be bent and causing it not to make contact and will need to be bent out a little to get it to work.
Jul 17, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
I have a dewalt DW005 24V hammer/plus drill i am having problems charging batteries. the L.E.D lights flashes as though its charging but it has stopped showing continuous light as it should do when fully...
The battery has probably lost it's ability to receive a charge. Is it old? Check the output of charger, should be around 26 volts DC at the output jack.
Jun 25, 2009 | Dewalt DW005K Rotary Hammer
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
