Question about Yurbuds LaMichael James Signature Series ITE 100 Earbud Headphones
Sound gone in left
Sound is gone in left earbud, tried to move around, sound goes in and out, like a short
Is there a way to fix my earbuds when only one side works, but when i move around the wire both sides work. Or do I need to get new earbuds?
This happens because on of the wires inside the cable that goes to the faulty earbud is broken so it makes contact just by accident. This is unfixable, you need new ones.
Sep 06, 2011 | Audio Players & Recorders
Hi, I bought a pair of sony bubble ear buds less than a month ago and was really enjoying them, but the left earbud has gone completely silent. I take good care of them and don't ever play my music...
its probably not the earbuds just that it seems all sony mp3 players have a problem in which the left side contact in the jack (the hole that the earbuds plug into) goes bad had this happen on the third player so far .
Aug 13, 2010 | Sony Audio Players & Recorders
My apple ipod, 8gb, 4th gen. has an audio jack issue. The earbud cord was yanked from the ipod while moving and since that time, the sound will only come out of the left side of any WORKING earbuds I try....
Hi jodisully,
sorry for my previous confusion, you can change the audio jack easily, purchase the audio jack from the below link -
http://www.kingipod.com/4g-ipod-parts.html
Please follow the below link to know how to replace them -
http://www.ipodhowtovideo.com/4thgen/4gheadphonereplacement.html
(jack cost is around 5 usd only, and there are complete help regrading replacement)
Please post comments for more information.........
Good luck!!
Thanks
Jan 06, 2010 | Audio Players & Recorders
The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
Aug 28, 2009 | Audio Players & Recorders
Sweat got into earbud- sound very faint
That happens because the water and saline solution in the sweat are causing the wires inside the earbud shorting to each other, or shorting to the earbud casing that is grounded.
Let the earbud dry out in few hours or more, if the problem does not go away, then get replacement heaphones, it means that oxide formation on the contacts is causing a short.
Do not use shorted hearphones they can cause damage to the connected device.
Regards.
May 04, 2009 | Shure SE530PTH Professional Headphones
Sound in left earbud shorts in and out
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
Mar 02, 2009 | Etymotic Research Isolator ER-6i Consumer...
Sound louder in right Ear!
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Feb 09, 2009 | Itech Blue Pro Bluetooth Stereo Headphones...
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Aug 13, 2008 | Skull Candy LINK Earbuds Consumer...
Sound Gone
I lost the left side. Everything else still works
Feb 24, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Yurbuds LaMichael James Signature Series ITE 100 Earbud Headphones Logo
Top Yurbuds Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yurbuds Audio Player and Recorder Expert? Answer questions, earn points and help others
