Question about Victor Office Equipment & Supplies
Replacing calculator paper
Taking roll off and inserting new roll
SOURCE: Changing paper roll on Citizen CX-121 Calculator
At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
Posted on Apr 11, 2008
SOURCE: BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Posted on Oct 31, 2008
SOURCE: Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Posted on Apr 13, 2009
SOURCE: I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Posted on Oct 06, 2009
old marine
  • 1983 Answers
SOURCE: My calculator refuses tocatch a new roll of paper
Try folding the paper over at a 45° angle and feed it in.
Posted on Feb 15, 2010
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you load the paper on this adding machine?
      • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
      • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
      • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
      • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
    Jan 30, 2011 | Canon P23-DHV Calculator
    How do you put the adding paper into the machine? My machine is a EL-1197iv
    Never insert paper roll if torn. Doing so will cause paper to jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig. 2)
    3) Insert the paper roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Jan 03, 2011 | Sharp EL-1197PIII Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    jam.
    (Fig. 1)
    2)
    3) Lift the attached metal paper holder up and insert the paper
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    Replacement paper roll size???
    Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
    Sep 26, 2009 | Sharp EL-1197PIII Calculator
    Apr 09, 2009 | Sharp EL-1801C Calculator
    Where do i put the paper into to replace a new roll
    There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
    IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
    Feb 04, 2008 | Sharp EL-1701C Calculator
    Cannot Laod the paper
    1. The end of the paper roll can be cut on either a straight-edge or angled slant. 2. Remove the top cover of the calculator. 3. Insert the paper into the narrow back slit on the back of the calculator so that it feeds under the black plastic plate. The slit is located on the outside of calculator. 4. Use the Paper FEED button to advance the paper up. 5. Replace the cover and feed the paper through the cover opening. Hope this helps. Slit for paper is not immediately obvious, so don't put yourself down.
    Feb 19, 2007 | Canon P23-DHV Calculator
    Top Victor Office Equipment & Supplies Experts
    Greg Cann
    Greg Cann
    k24674
    Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
