Logik air conditioner manual
Where can i find a logik portable air con manual for a 14000 btu unit?
SOURCE: User manual
I have the same unit, we've used it most days in our office since beginning of April and it's just cut out. I removed the drain plug at the base of the back and drained out about 1 litre of water. It's now working perfectly again. My guess is depending on the humidity it should run about 1 full month before emptying
Hope this helps
azzymodo
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: Amana portable air conditioner will not turn on.
drain the water. Same problem, it fixed it. alot of water in there Be careful
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
  • 4 Answers
SOURCE: We purchased a Maytag 8,000
Here's where I published my copy of the User Guide for NMPEB08F2A (7 pages): http://usermanualnmpeb08f2a.yolasite.com/
Posted on Oct 04, 2010
I have a 14000 BTU portable air conditioner Hisense, was working went i go to bed, now is not , there is power supply but ac is dead
Many times on these units a start up capacitor fails. They are cheap an easily replaced. But you will need a tech to do it unless you can work with electronics.
Jul 20, 2017 | Heating & Cooling
Why won't my Haier CPN14XC9 wont start when i plug it in
Check the plug reset switch. Sometimes they are bad. If you have a meter test where the wires connect to the unit. You should get a reading of 120vac. If you don't get this reading, its the plug. If you do its going to be a capacitor. The capacitor will be small because its a small unit.
Jul 22, 2014 | Haier CPN14XC9 14000 BTU Portable Air...
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
Fuse keeps blowing on my Whynter portable ac
Is your compressors motor capacitor replaceable? I know that on a split system, a dead capacitor (typically a 35uF) can cause increased current draw, to the point of blowing fuses, though I've never had to replace one on a portable unit. I usually replace them with a 30uF capacitor, roughly the size of a "200ml can of softdrink".
Apr 11, 2014 | Whynter ARC-14S ECO-FRIENDLY 14000 BTU...
Why do i have to empty the water out every 2 hours 14000 btu portable plus humidifier aitconditioner 14200 btu heat pump
That is normal for a portable a/c unit if it has a drain on it you can put it on a shelf or counter and allow it to drain to a floor drain or sink. some newer units come with a pump to remove the condensate, this is the water you normaly see driping out of the a/c units in windows
Jul 21, 2011 | Soleus Heating & Cooling
Dont have book...dont know how to clean unit
The manual doesnt give much insight. Vacuum/wash(no dishwasher) the filter(remove by pushing down and away from the unit. Its right on top on the back. As alway unplug before. Wipe the outside. thats it in the manual.
Jul 07, 2009 | Amana Portable Air Conditioner
Heating & Cooling Logo
453 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
