Question about Compass GPS
How to get gyro error? - Compass GPS
Need starter diagram for 1985 Honda gyro TE50 scooter
Hi, Wendy this is a very rare and old scooter and probably worth "BOO KOO DRACHMA" for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://projectmopedmanual.info/manuals/honda/honda-tg50-gyro-shop-manual.pdf
http://projectmopedmanual.info/manuals/honda/honda-tg50-gyro-shop-manual.pdf starter info
Honda Tg50 Gyro 1986 Usa parts lists
Feb 16, 2017 | Honda Motorcycles
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Jan 21, 2013 | SYMA Toys industrial New Syma S107 Radio...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Free honda gyro s repair manual download
Hi, Ted the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 sometimes more and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, then there is eBay where you may be able to find what you need at a very high price because of its age and rarity. Most of the "FREE" manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day.
http://www.motorscooterguide.net/Manuals/Honda_TG50_Service_Manual.pdf
Honda TG50 Gyro Manual
Honda Gyro 2013
Honda Gyro Wikipedia
May 17, 2012 | Honda Motorcycles
HONDA CANOPY mono shock
Hydraulic MD302-215P-02 215 10X20 FORK 11 E-Series ME302-215T-02 215 10X20 FORK 11
Jan 12, 2012 | 2006 Honda Gyro Canopy
What is the formula in solving gyro error?
http://www.towage-salvage.com/files/HANDBOOK8.pdf
On the 3rd page it will give you the formula for gyro calculation.
Sep 25, 2011 | Navionics Jabsco XL9 - Great Lakes and...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Helico
Gyro is oriented, flip it over, or turn it 180, see if this solves the issue
Jan 23, 2009 | GWS Pg-03 Micro Piezo Gyro Pg03 Heli...
GPS Logo
12 people viewed this question
Top Compass GPS Experts
Are you a Compass GPS Expert? Answer questions, earn points and help others
