Question about Konica Minolta Office Equipment & Supplies
Connection error connection timeout
  • Konica Minolta Master
  • 6,161 Answers
From which model machine
Posted on Jan 18, 2016
Oki b430 error timeout
It is a timeout value which works only when a job
with a specified size is received.
Apr 24, 2014 | Oki Electric Industry Office Equipment &...
I keep getting an error 504 when trying to connect to a website. What is this and how do I fix it
A 504 error is a Gateway Timeout and is a problem on the website side not with your computer or internet connection. Try doing a reload or waiting for a while then try again as the server problem may be temporary or perhaps just a scheduled reboot.
If you continue to receive to the 504 then you should contact the website concerned to notify them of the 504 timeout.
Oct 17, 2013 | Acer Computers & Internet
Connection timeout and connection errors
my new phone keep goint to timeout everytime i try to use it
Oct 03, 2013 | Straight Talk Huawei Ascend Y Cell Phone
I get a timeout message at the end of a print run
Toggle through the menus on the printer to the "Sys Config Menu" and turn OFF both the "Manual Timeout" and "Timeout in Job".
As a note, we only have this issue crop up when our printer is accessed through an Apple Time Capsule. When it was directly attached to the computer, or accessed directly through IPP we had never had the error page print.
Jun 03, 2012 | Oki Electric Industry B431dn Printer
Failed to register! error-code: 408, msg: 'Request Timeout'
Errors / Solutions (Error 408, 401, 503 / Not Connecting / Failed to Register / Audio Problems):
You can try using port 8891 or 80 setting if 5060 port is blocked
Simply change the sip.tpad.com settings in Xlite to
sip.tpad.com:8891
or
sip.tpad.com:80
Use our STUN Settings, simply use the info on this link (stun.fwdnet.net:3478)
http://forum.tpad.com/viewtopic.php?t=617
http://www.youtube.com/watch?v=ugHwkl--zhQ
Use these other Free Softphones with Tpad:
http://forum.tpad.com/viewtopic.php?t=623
http://forum.tpad.com/viewtopic.php?t=864
http://forum.tpad.com/viewtopic.php?t=657
http://forum.tpad.com/viewtopic.php?t=456
May 02, 2009 | Computers & Internet
I just figured out what you ment
Possible Cause Action
The SMTP server is not in
service.
Check with the network
administrator.
IP address of the SMTP
server is wrong.
administrator and enter the
correct IP address.
Port number is wrong.
correct port number.
A timeout condition occurs.
Set a longer value for “SMTP
Connection Timeout.” The timeout
value depends on the
network’s traffic conditions
and load on the FTP server.
The network is disconnected
during file transfer.
Send Ping from PC to the controller
and SMTP server to
check to see if both parties are
connected to the network or
not.
For any clarification on the procedures.
See “User’s Guide
[Network Scanner
Operations].”
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Message ID . . . . . . : CPA403D Severity . . . . . . . : 99 Message type . . . . . : Inquiry Date sent . . . . . . : 12/11/08 Time sent . . . . . . : 15:13:47 Message . . . . : Operator action required on...
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Dec 11, 2008 | HP LaserJet P4014n Printer
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
I have problems to connect my LG KG800 WITH THW PC
same thing is hapenning with my phone LG RUMOR
when ever I am trying to connect internet it says NETWORK TIMEOUT ERROR 7 ...
any IDEA ???
Jan 12, 2008 | LG KG800 Cellular Phone
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
