Question about Tefal ActiFry Deep Fryer
No power in actifry
Tried fuse in plug in something else and it not fused what is the best thing to try next
I have a Sony TV model number KDL-46VE5 it doesn't turn on, there is no red power light when I plug it in and I have tried several outlets, can u help me figure out what's wrong with it.
check the fuse inside the power plug
check for any internal fuses blowing.
If these are all right it is probably something to do with the power supply to it.
Using a multmeter I would check that the set is receiving power. Next, if power is reaching I WOULD CHECK FOR DAMAGED CONDENSERS/ CAPACITORS ON THE POWER CONTROL CARD....SEE LINK BELOW FOR POSSIBLE REMEDY
https://www.youtube.com/watch?v=I8teB16U0LA
Jun 17, 2015 | Sony Televison & Video
Coffee maker
Next thing to do is check the plug fuse.
May 08, 2013 | Coffee Makers & Espresso Machines
It doesn't power up
There is a small power button at the base of the device. No offense, but are you sure this is still pushed in to the "on" position?
Also, I have the same device, but I did blow my fuse. However, I lost it and cannot remember the number on the fuse. Would you be willing to post the fuse replacement part number for me?
Mar 26, 2012 | Pro Power GOgroove FlexSMART X2 In-Car...
I have one headlight out on my E350 Diesel. I have tried switching out the headlamp. But that did not work. I checked with a power gauge and there is no power getting to the headlight. I was told that it...
Go back and check fuses. Alot of vehicle use seperate fuses for each headlamp system. If you had a short there would a blown fuse and those circuits are big amperage so yu might even smell something burning. Check all your fuses
Jul 20, 2011 | 2002 Ford E350
Bang then no power - LG Microwave
either the h.v. diode,h.v. capacitor,thermal fuse (in some) or the magnetron tube are defective
Oct 19, 2009 | Microwave Ovens
RCA 32V430T 32" won't turn on!
The fuse is inside the set and is probably ok, but check to be sure. If you have an ohm meter I would check the horizontal output transistor first. It is a big transistor on a heat sink next to the FBT. It has three pins, check the center pin to one of the others, if low the transistor and probably the FBT is bad.
Sep 05, 2007 | RCA 32V430T 32" TV
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
Power supply gone bad
Canon 9080C is a very good scanner, so dont dump it.
Yes all power supply units have a fuse. Check if it is okay. You can source scanner power supply board from the market, if you can handle it or it is easy to call Canon support and get it fixed.
Oct 11, 2006 | Canon DR-9080C Path-Through Scanner
Tefal ActiFry Deep Fryer Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
