Question about iLive Itp180b Ipod(r)/iphone(r) Speaker Bar
Static I am using the speaker with my computer and all I am getting is static
Major static with bluetooth speaker
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Feb 23, 2014 | Jabra Solemate Speaker System - Wireless...
Dell 5650 speaker issues
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Dec 22, 2011 | Dell 5650 Computer Speakers
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Altec-Lansing VS-2120 speakers problem: Right speaker gives no sound, although computer checks out on other speakers, and headphone plugged into this speaker set works on both channels. Also get static...
hope this helps you
Aug 30, 2011 | Computers & Internet
I get static interference noise
hope this helps
Aug 07, 2011 | Altec Lansing Multimedia Computer Speakers
I purchased theses speakers January, 2011. At first they worked fine. Then I started having problems getting sound out of the left speaker. The sound would return when I plugged and unplugged the speaker...
hope this helps
Jun 04, 2011 | Bose Companion 2 Series II Multimedia...
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
Why does my left speaker sound extremely static?
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Philips SPA1312 2 Speakers
Loud static sound comes from computer speakers and the phone
Uninstall and reinstall new drivers for your sound card from the soundcard manufactures website or if its onboards from the PC makers site. If your using vista their has been widespread issue's related to the static "bug" and numerous solutions that sometimes work or do not work have been tried. ex; if is a soundblaster card try Creative.com's forums.
Apr 16, 2009 | Altec Lansing VS2221 Computer Speakers
iLive Itp180b Ipod(r)/iphone(r) Speaker Bar Logo
15 people viewed this question
Top iLive Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an iLive Cell Phone Expert? Answer questions, earn points and help others
