Question about Panasonic CT-36D32 36" TV
I hit restore to factory settings, big mistake
Was trying to set up a HD converter box, while scanning for more channels I went to factory reset. Now I only get two channels instead of the seven I used to get and they don't come in all that good. I tried to use the TV remote to go to menu but it won't do it. How can I get back off the factory reset.
MikeNJ1964
  • 398 Answers
SOURCE: program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Posted on Jul 26, 2007
ladywinn
  • 5138 Answers
SOURCE: How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Posted on Dec 21, 2007
SOURCE: DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
Posted on Jan 03, 2008
  • 113 Answers
SOURCE: Just a line on the screen?
Your tv has a failure in the vertical circuit. Most likley since you explained that it was coming in and out you could fix it by Resoldering the connections on the vertical output IC. Replacing the vertical output IC would be your next step after this.
-Josh
Posted on Mar 04, 2008
  • 47 Answers
SOURCE: dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Posted on Apr 05, 2008
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
How do I fix my Sony Bravia to be able to scan for free to air digital channels?
Hi
after factory setting please select both option to scan digital as well as analog channels then you can scan these channels
Feb 23, 2015 | Sony Televison & Video
Hooked up a HD converter box. Lost TV
The issue should not be with your TV, I would be with the digital converter box or more than likely with your cable feed from your antenna. If you purchased a cable with connectors already on the wire, maybe the wire is okay. If you installed your own connectors on the cable, if they are twist on connections, you need to be sure that the outer braid makes contact with your connector. Double check your connections to and from the converter box as well to be certain you have not confused the antenna in and the TV out. I hope these tips help.
Oct 11, 2017 | Panasonic CT-27E13 27" TV
I accidentally hit the A / B Button and now the picture disappear. How can I restore?
Try to reset the LCD to factory defaults by pressing menu > set up and scroll down to restore all. Have the satellite cable on before you try to run the auto channel scan.
Dec 01, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Have sony kdl40ex400, tried initial setup to cable, must have done something wrong, can only get channel 4, even when not going thru cable box
Tries tv and the cable box unplug,replug it back like an hour later.The tv now resetting it self back to the factory setting.The cable box it resetting and upgrading it softwares.Now plug the tv back through the cable box again.Now go into ur tv menu select Cable and scan for Cable channels again.Now u should have all ur pay cables channels now.
Nov 17, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Lost most channels any new codes please
Hi if you do a factory reset then turn off the box leave it off for about 30 seconds. turn it back on and do an automatic scan make sure your emu key is on and it should be working, thats what i did with mine.
Hope this helps.
Apr 29, 2010 | StarTech.com StarView SV211K 2-port KVM...
Did power scan by mistake and now no channels
restore to factory defaults and than delete all the data ( all the channels ) once done . run power scan and your box should be up and running again..... :)
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Sep 19, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Panasonic CT-36D32 36" TV Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
