Question about Riso Office Equipment & Supplies
Error Code P-17--20 on my EZ220U Riso what does this mean?
Machine do not copy after master making and P-17--20 code is display.
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: Error Code H101 on my EZ220U RISO--what does this
You will need to go into service mode, to input the value on the machine for the ink color the value is 1-black or 2-color.
Hope helps.
Posted on Jun 02, 2011
ERROR D-08-224 ON DISPLAY
Error type D08: Master making unit not setError point 224: Master making unit is not set (both the safety and lock sensor are OFF)
Try this: Set the master making unit in place.
Aug 15, 2012 | Riso Office Equipment & Supplies
Error Code H101 on my EZ220U RISO--what does this mean?
Hope helps.
Jun 02, 2011 | Riso Office Equipment & Supplies
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
Feb 04, 2011 | Office Equipment & Supplies
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
Error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Nov 30, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
E11 on riso gr 1700
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Dec 21, 2008 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
134 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
