Question about Sloan 180-1 Exposed Urinal Flushometer - 1.25" Top Spud
Constantly runs watercontinouslyruns
I have installed a brushless constant pressure water pump that keeps coming on constantly... is that a problem for this kind of pump? is that a potential issue?
Motors like to run. It is the starting and stopping that puts the most wear and tear on motors. In order to maintain a constant pressure, the pump must always run.
Feb 14, 2017 | Plumbing
My plumber says the pump should not run constantly, but should switch on and off. It come on for about 15secs and then off. I want it to run constant, will it create problems?
Assuming you do not build up really excessive pressures and the motor is not straining, running the motor constantly is better than having it cycle periodically. Every time a motor turns on a tremendous amount of juice goes into the motor windings until the motor speeds up and the back emf reduces the current. A constantly running motor will run cooler and last longer.
Oct 20, 2015 | Plumbing
Constantly runs
Zone valve stuck, or switch on zone valve faulty.
Jan 05, 2014 | Biasi B-6 Oil Boiler w/ Riello Burner -...
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Jun 03, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
Radio constant wire problems
To bypass a constant just run a wire from the battery to the stereo. You can also run it from the ignition constant. I would recomend a wiring diagram. You can get a manual for almost any repair from autozone or oreillys
Apr 28, 2009 | Chevrolet Venture Cars & Trucks
Inside fan runs constantly on my AC
Raise your thermosat to about 78. Also check to make sure the thermostat is set to auto and not on...
Jun 12, 2008 | Whirlwind FH-778 Air Conditioner
Water pump constantly running on Carrier gas furnace
Yes I agree with Master_tech Be sure the shipping retainer was removed if its a new unit, if its an old unit clean it and put an algae tablet in it.
Mar 04, 2008 | Carrier 38CKC036 Air Conditioner
Sloan 180-1  Exposed Urinal Flushometer - 1.25" Top Spud Logo
Top Sloan Home Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Sloan Home Expert? Answer questions, earn points and help others
